CS324-T and IPP.ME for Cavalier
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7823
Printed Date: April 25, 2026 at 1:34 AM
Topic: CS324-T and IPP.ME for Cavalier
Posted By: Vetteandi
Subject: CS324-T and IPP.ME for Cavalier
Date Posted: January 08, 2003 at 8:55 AM
Hi All,
Been following the last few posts on this and I have ordered a 324T and IPPME for my 2001 Chev Cavalier.  I made note of all the posts and think I have a good idea on how to hook this puppy up.  Only Question I have is on the Starter Inturrupt relay.  I do not have one and was wondering what is the purpose of that function?  All I want for the car is to start remotely (I do not have power locks so that function is moot) and to be able to shut it off if I have to via remote or the 20 min timeout.  Is this starter relay or is that wire required to be hooked up to have this function?
Posted By: jrilla
Date Posted: January 08, 2003 at 11:07 AM
The start interrupt relay is an additional relay that you install between the starter wire if you want to have an anti-grind feature. It is not necessary, but it will prevent you from grinding the starter if you turn the key to the crank position after it has been remotely started.
J Rilla
Owner/Installer
