remote start, 2004 isuzu rodeo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78308
Printed Date: May 07, 2026 at 6:11 PM
Topic: remote start, 2004 isuzu rodeo
Posted By: slimshady
Subject: remote start, 2004 isuzu rodeo
Date Posted: May 25, 2006 at 8:13 PM
Ok guys i bought a code alarm a670 i have it all in stalled and every thing works perfect except the remote start i can't get it to even attempt to crank the starter the only way it will ingade the starter is if i turn the key to run.. with out the key all it does is turn the acc's on and then back off when the start fails... I have a 2004 isuzu rodeo, and i have the dei universay bypass with a key installed in it, I also need some help installing that in not sure on the antenna pice wheather i can tap into the existing 2 wires coming from the key or is i need to put that ring arounf the key or what the ring is kinda big. so any one that can please help me out with this once again installing the bypass model and what im missing the reason the starter wont even kick in even with the key in the ignition.
Posted By: spookiestylez
Date Posted: May 25, 2006 at 10:24 PM
you need a universal bypass module sS
Date Posted: May 26, 2006 at 1:04 PM
i do i have a 556u in there dei but im not to sure of how to hook it up to the ignition, plus i must need to hook up another wire cuz even with the key in the ignition it can't cracnk the starter untill i turn the key to run then the alarm can crank the starter and start the car..
Posted By: Twelvoltz
Date Posted: May 26, 2006 at 2:12 PM
It sounds to me as if you may have a wire that is supposed to be fed by a constant hot being energized by a wire that is a switched hot.
As far as the bypass is concerned, does the vehicle start and run when the key is left in the on position? I would recommend gettting the remote starter working when you leave a key in the ignition before troubleshooting the bypass module.
Date Posted: May 26, 2006 at 9:22 PM
Yea i can hit the start button and get out of the car and it keeps runnign the radio stays on and the ac keeps blowing just as if the key was in it. adn i went through and checked all the ignition wiring again, and as far as i can see its all hooked up right ive done these remote starts before but always with viper ive never done a code alarm before and I think thats what is messing me up.. every wire in the ignition harness is tapped except 2 litle WHITE/ pink stripped ones and theres notthing that says what they are for
Date Posted: May 26, 2006 at 11:29 PM
For a test, run the constant hot inputs to the remote start directly to the + battery terminal, fused at the battery. Then retry the unit, with your key in the off position but in the key cylinder.
Date Posted: May 27, 2006 at 3:27 AM
Actuly i got it finnaly I did have 2 of the ignition wires backwords. i swapped them around and it cranked and putting in the by pass was a breeze, heck i even got the 2 step door locks working, rear defroster, horn and headlights so every thing is hooked up now and working perfectly I think my next task will be a window moduel.. thanks for the help guys..
