infiniti immobilizer bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78396
Printed Date: May 07, 2026 at 3:40 AM
Topic: infiniti immobilizer bypass
Posted By: murzik
Subject: infiniti immobilizer bypass
Date Posted: May 28, 2006 at 4:57 PM
I have 06 G35 coupe with intelligent key. I try to install remote starter. Every thing looks ok, but I can’t get immobilizer bypass module 556U to work. If factory alarm is active car won’t start. If factory alarm is not armed or I live key in ignition car starts just fine. Do I need to do anything specific for infinity? Or do I need different immobilizer bypass module?
Posted By: Chris Luongo
Date Posted: May 29, 2006 at 9:46 AM
Did you power up the RED / blue keysense wire as Ignition 2? You need to do tha if it has the Intelligent Key.
Posted By: murzik
Date Posted: May 29, 2006 at 11:58 AM
Thanks, That was it.
However, I used ignition2 as starter 2.  What can I use for keysense?
