95 gmc jimmy remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7854
Printed Date: April 18, 2026 at 3:56 PM
Topic: 95 gmc jimmy remote start
Posted By: ryan3738
Subject: 95 gmc jimmy remote start
Date Posted: January 08, 2003 at 6:57 PM
I recently purchased a remote start/security system and was wondering how to install it on my truck.  Or just a wiring diagram of the truck would do.  Will this be hard to install and will i need any extra parts.
Posted By: INSTLEADA388
Date Posted: January 08, 2003 at 8:07 PM
 ALRIGHT, FIRST OF ALL IF YOU HAVE NEVER INSTALLED AN ALARM AND/OR REMOTE START BEFORE THIS WILL PROBABLY BE HARD TO INSTALL. THE USE OF A DIGITAL MULTIMETER IS A MUST.  ANY WAY HERES THE INFO:                                       12 VOLTS/RED / IGN HARNESS      STARTER/YELL/IGN HARNESS     IGN1/PINK/IGN HARNESS        IGN2/WHT OR PNK/WHT/IGN HARNESS      ACC/ORG/IGN HARNESS   LOCK/LT.BLU  (+)  UNLOCK/WHT (+)/EITHER KICK PANEL    PARK LTS(+) /BRN/SWITCH OR HARNESS TO REAR OF TRUCK       DOOR TRIGGER/WHITE(-)
HATCH RELEASE  BLK/WHT (+) AT SWITCH          TACH/ WHT /AT COIL ON TOP OF ENGINE              BRAKE WIRE/ WHT/  AT BRAKE PEDAL SWITCH
ALL THESE WIRE COLORS AND LOCATIONS SHOULD BE CORRECT IF YOUR TRUCK CAME WITH FACTORY KEYLESS ENTRY ,THE LOCATION OF THE DOOR TRIGGER VARIES .  IT SHOULD BE AT THE KEYLESS MOD LOCATED UNDER THE DRIVERS OR PASS DASH. I DONT KNOW WHAT KIND OF ALARM REMOTE START YOU HAVE BUT ADDITIONAL RELAYS MAY BE REQUIRED FOR THE DOOR LOCKS , HATCH RELEASE, AND PARKING LIGHTS ( ALL POSITIVE TRIGGERS) READ THE INSTALL MANUAL , AND DOUBLE CHECK ALL WIRES WITH A METER .
   GOOD LUCK!!!
