99 camery two stage door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78641
Printed Date: March 25, 2026 at 7:08 PM
Topic: 99 camery two stage door locks
Posted By: jdalarm
Subject: 99 camery two stage door locks
Date Posted: June 02, 2006 at 11:05 PM
I just installed a new alarm, remote start, keyless entry sytem into my 99 toyota camery but can't figure out how to get it to unlock the drivers side door first, then unlock the passengers doors by pushing the button again.
The cars diagram gives the following.  Door lock (light green wire), Door unlock (RED / green wire), Drivers lock (blue wire) Drivers unlock (RED / green wire), Passenger unlock (dark green wire)  These are all located at the left Kick Panel.
The Alarm has the following wires for Door locks. 3-pin connector with Blue Wire (unlock output) and Green Wire (Lock output), It also has one wire off the main 20 pin harness Blue/White Wire (passenger unlock output).
As is I have the cars+alarm wire (light green + green wire), (RED / green + Blue), (dark green + Blue/white)
Thanks,
Posted By: spookiestylez
Date Posted: June 02, 2006 at 11:08 PM
what kind of alarm??
sS
Posted By: jdalarm
Date Posted: June 02, 2006 at 11:13 PM
The alarm is a Galaxy 5000RS
Posted By: jdalarm
Date Posted: June 04, 2006 at 12:12 PM
still need help with driver priority setup on 99 camery. The door locks work fine with the second push of the alarm but still can't get the driver door to unlock first I've tried several different wires and blew a few fuses but still no luck. Not sure If I am using the relay correct or even using  the right wire.
Right now I have the alarms Lock wire hooked up to the Door lock wire ( light green) and the Passenger unlock wire hooked up to the door unlock wire (green) just not sure which wire to cut and hook to the relay with the alarm unlock wire.
Josh,
Posted By: jdalarm
Date Posted: June 04, 2006 at 6:01 PM
ok now I have it so I can unlock the drivers door then unlock the other doors but now I can't get the drivers door to lock.posted_image. All the other doors lock just fine. To get the drivers door to unlock first II tried hooking up the relay like the manual says but every time I tried connecting 87a back to the door lock module it would fry a fuse. So I left the wire from the door module left unused. thinking about how to get the drivers door to lock with the others,
Any Help, Thanks, JOSH
Posted By: Chris Luongo
Date Posted: June 04, 2006 at 11:16 PM
You'll need to connect 87a back to the factory doorlock module, and troubleshoot and correct whatever problem is blowing the fuse.
Posted By: jdalarm
Date Posted: June 06, 2006 at 11:53 PM
Starting over with the door locks, can any one tell me which wire I need to cut and hook to the relay for driver priority. I've got the Main Lock and Unlock figured out but when I check out the wiring diagram at https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1999&make=Toyota&model=Camry&ID=18959&type=Alarm
It says the drivers unlock is a blue/red wire, but I found 2 blue/red wires coming out of the drivers door. one wire is a little larger than the other. I went as far as to take of the door panel and find out which wires were running to the door locks I found one plug with 4 wires a small blue/red, large blue/black, large blue/red and a small WHITE/ black. then there was also a smaller plug with 3 wires small RED / green, small blue/white, and small WHITE/ black wires.
my main lock wire is hooked up to the door switch which is a light green wire and the main unlock wire is hooked up to the door switch which is a dark green wire.
thanks, JOSH
