Alarm keeps going off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78718
Printed Date: March 29, 2026 at 8:07 AM
Topic: Alarm keeps going off
Posted By: billrc
Subject: Alarm keeps going off
Date Posted: June 04, 2006 at 8:53 PM
When I bought my 95' Toyota camere station wagon I had a factory installed Viper alarm system put in. Last week something happened. It kept going off and it drained my battery. I know it's been eleven years but it has worked great all that time. Does anyone know if after time this is a common occurrence? Do alarms just short out like this? Is there an easy fix?
Thanks,
Bill
Posted By: spp8969
Date Posted: June 05, 2006 at 3:31 PM
Hi Bill,
I don't have much knowledge in the alarm systems and i myself just bought an omega car alarm and i'm installing it with my friend who installed a viper alarm 4-5 years ago on his mercury van. Wierd thing happened a month ago - his alarm just went crazy and pretty much completely stopped working. after that all he did was to reset and then reprogram the brain and now it works fine again. so if your alarm just started going crazy all of a sudden you might want to look for the viper's manual and reprogram the system or have somebody do it for you if you don't know how.
Hope this helps,
Svilen
P.S. also you might want to check your shock sensor, if you have one, because it might have gone bad and just be setting of the alarm all the time.
Posted By: billrc
Date Posted: June 05, 2006 at 3:54 PM
Thanks Svilen - Yes I'm going to bring it in tomorrow to a dealer and see what they say. I had Toyota disconnect it for now so it doesn't drain my new battery.
Bill
