2007 suburban remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78971
Printed Date: April 08, 2026 at 9:38 AM
Topic: 2007 suburban remote start
Posted By: jmacf14
Subject: 2007 suburban remote start
Date Posted: June 10, 2006 at 8:05 PM
Does anyone have the wiring info for a 2007 suburban Ls? also if you know what bypass modules for this rig. thanks in advance! ------------- jmacf14
Posted By: Velocity Motors
Date Posted: June 11, 2006 at 3:54 PM
PLJX-UTI - Combo GM Passlock (ALL) + Universal Transponder Bypasskit  As far as the wiring information, there's nothing yet that I have. ------------- Jeff
Date Posted: June 11, 2006 at 3:56 PM
Date Posted: June 11, 2006 at 3:57 PM
 | Door Lock Circuit | | DATA BUS | | |  | Databus Wire | | PIN 1 | | |  | Driver Mtr Unlock | | PURPLE | | (REV) | | IN DRIVERS DOOR | | |  | Driver Mtr Lock | | GRAY | | (REV) | | IN DRIVERS DOOR | | |  | Pas Mtr Unlock | | GREY/BLACK | | (REV) | | IN PASSENGER DOOR | | |  | Pas Mtr Lock | | TAN | | (REV) | | IN PASSENGER DOOR |
------------- Jeff
Date Posted: June 11, 2006 at 3:59 PM
I lied, above is the wiring information so far, but remember that you HAVE TO DOUBLE check all connections prior to connection to the remote starter for accuracy of this information.
------------- Jeff
Posted By: mo12v
Date Posted: June 11, 2006 at 6:02 PM
Also, Get your MAIN Power from Battery & NOT Ignition Harness
------------- MO
Posted By: jmacf14
Date Posted: June 11, 2006 at 6:26 PM
thanks for the help guys, I appreciate this very much., also, I,m curious what video monitors that you prefer for installing in the headrests? tnx
