wire 12v bulb with led to blink
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79246
Printed Date: April 07, 2026 at 4:01 AM
Topic: wire 12v bulb with led to blink
Posted By: gtstang03
Subject: wire 12v bulb with led to blink
Date Posted: June 17, 2006 at 1:56 PM
how would you go about wiring up one of my corner marker 12v light bulb to blink with the led when the alarm is set. I have seen this and would like to do this.
I have the viper 350v alarm with blue led.
Posted By: auex
Date Posted: June 17, 2006 at 4:12 PM
Shouldn't do it, it will kill your battery. What you can do is install a led into the corner lights and wire them into the led output of the alarm though. Also the led output will not provide enough current to trip a relay.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
