04 mailbu disarm factory security
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79364
Printed Date: April 07, 2026 at 8:10 PM
Topic: 04 mailbu disarm factory security
Posted By: xtremej
Subject: 04 mailbu disarm factory security
Date Posted: June 20, 2006 at 11:36 AM
I installed a remote start on a 2004 malibu. The factory security goes off with this scenario, locked at the door switch and closed, unlocked by remote start remote. My question is if I pulse the ignition will it disarm the factory alarm so it doesn't go nuts? Or should I have them only use the aftermarket remote to control the locks?
Posted By: Chris Luongo
Date Posted: June 20, 2006 at 4:10 PM
If you use the aftermarket system to pulse the ignition AND the transponder bypass, it should work.
Or, as you say, just tell them to pick one of the remotes for the locks, and stop using the other one.
Posted By: sparkie
Date Posted: June 20, 2006 at 7:59 PM
There is a light green wire in the driver's kick panel coming in from the door. A negative pulse through a 620 ohm resistor will disarm the alarm. A second pulse will unlock the doors. Use a relay to insure a proper ground signal through the resistor.
------------- sparky
Posted By: ushank
Date Posted: June 20, 2006 at 10:52 PM
Try using a by-pass module. Peripheral PPLXR (PLGML) You can also try the directed peice that can be picked up at any of your local alarm shops.
Posted By: xtremej
Date Posted: June 21, 2006 at 10:18 AM
Cool thanks for the reply.
