2003 f150 remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79435
Printed Date: April 06, 2026 at 3:59 PM
Topic: 2003 f150 remote start
Posted By: james betts
Subject: 2003 f150 remote start
Date Posted: June 22, 2006 at 12:20 AM
I made the mistake of purchasing something from ebay now i need help. I purchased a huatai ht-800d+ 2 way  remote start/alarm i have instaled other remote starts but this one has some diferences it dosent have a tack wire it uses oil pressure or charging ? it has 1 str wire, 1 acc wire, and 1 on wire ( i asume ign 1 ) but ford has 2 ign wires dont i have to energize both ign wires? it has 2 wires for turn signals can i just hook 1 of them to park lites like most alarms.  it has a wire and relay for start interupt do i have to hook this up ? do you know if my truck has + or - door locks  any help would be great.
thanks
james
Posted By: forbidden
Date Posted: June 22, 2006 at 1:10 AM
James, free advice, put the thing right back on ebay, take the loss and learn from the experience. You will spend more time and $ trying to make it work as compared to purchasing the right RS/Alarm and going from there. Take the hit on the investment and aggravation right now as compared to the impending doom that my trusty crystal ball is predicting.
Date Posted: June 22, 2006 at 9:26 AM
thanks i hate ebay but am going to try and get it to work
james
Posted By: mo12v
Date Posted: June 22, 2006 at 9:41 AM
forbidden...............well Put........posted_image
You will have to use Relays for the additional Ign / Access.  Not to mention the Return % on this stuff.  More money spent.................
MO
Date Posted: June 22, 2006 at 3:07 PM
thanks forbidden it is starting to get to complicated for me do you know a shop in victoria that will do it ? i am not woried about frying the alarm but the electronics in my truck are another thing. if i faxed tou the schematic could i pay you to draw me a simple diagram ?
james
Date Posted: June 22, 2006 at 3:59 PM
James, as I said, stop now and call it a day. I would not recommend that you keep going with this alarm rs combo at all as the nightmare you are just starting to have will continue for as long as it is in the vehicle. Next major thing to consider. Look at this thread, the first picture was done by a shop in Victoria and is how all shops in Victoria when this customer enquired about install, said that they would do the job. Based on that, there is not one shop in Victoria that I can recommend to you. Time for a road trip up island to come see me by the sounds of it.
Posted By: jhull
Date Posted: June 22, 2006 at 7:49 PM
03 is the new body style....
you should only have one ignition wire and one accessory wire.
you only have to hook up one of the turn signal wires to your parking lights.
in order to use the oil pressure feature you have to find the oil pressure sender (its a pain)
Im 99% sure you have (-) door locks
but as you were already told these units arnt to good... i installed a couple of them for customers a good amount didnt work properly and i absolutly hate putting them in.
Date Posted: June 23, 2006 at 1:42 PM
o4 is the new body stile
james
Posted By: jhull
Date Posted: June 24, 2006 at 5:03 AM
ouch well in that case, you should have I believe 2 ignition wires and 2 accessory wires. unless you have the xlt then youll have i believe 3 igntion wires and 2 accessory wires. lock polarity all depends if you get under the drivers side dash and look up on the firewall if you see a white box mounted to the firewall you have a possitive trigger, if you dont have that box then you have a positive trigger that rest at ground so you have to 5 wire the locks.
