Windows up -I get warn away tone.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79444
Printed Date: April 06, 2026 at 11:58 AM
Topic: Windows up -I get warn away tone.
Posted By: sufferrar
Subject: Windows up -I get warn away tone.
Date Posted: June 22, 2006 at 9:41 AM
Here is what happens. when i arm my car both the back windows go up ,after 8 seconds both the front goes up. when the front goes up the shock sensor detects the movement of the glass and triggers the warn away tones. the alarm is a hornet 554t and the window module is a tarantula. this window module has no model number and has no adjustments. and it is programmed by the manufacturer to wind up 2 windows and 8 seconds after another 2. how can i prevent the warn way when the last 2 window is going up? the shock sensor is set to minumum sensitivity. previously i had the DEI window module and that worked perfect- but it's in my van now.
------------- "I'm So Loud It Hertz"
Posted By: auex
Date Posted: June 22, 2006 at 9:44 AM
Move the window module, it has relays and can actually set the shock sensor off.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: June 22, 2006 at 9:53 AM
I don't think so... the window module is in the body panel between the front door and the back door -where the seat belt assembly is located. the shock sensor is under the dash. it's too far for relays to affect - besides i have other relays closer to the shock sensor that doesn't trigger it.
It is the vibrations of the window/motor that is triggering the shock sensor when the window is rolling up.
Posted By: swamprat323
Date Posted: June 22, 2006 at 12:00 PM
then change the shock sensor. only probly have to do it a tad. or maybe have the front roll up first then the back last, windows MAY be far enough back NOT to set off the shock.
