Auxillary Start Connection
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79462
Printed Date: April 06, 2026 at 2:39 AM
Topic: Auxillary Start Connection
Posted By: carone
Subject: Auxillary Start Connection
Date Posted: June 22, 2006 at 3:19 PM
Hello
I had a battery separator installed in my 2006 Chevy Tahoe and I need to be able to get to the start position of the ignition switch which only has voltage when the ignition is in the start position to activate a parallel battery situation in a SEPARATOR to aid starting.
Basicly what I am looking for is a convenient place to attach a #14 gauge wire to a Sure Power Battery Separator. I do not want to have to get into the steering colum or any thing like that . I am hopeing to pick this up at a fuse block or somthing like that.
Any help in locating a point on the TAHOE would be helpful
Thank You
Frank
Posted By: mo12v
Date Posted: June 23, 2006 at 10:02 PM
Back of the Driver side Fuse Box:
BROWN 14 Guage wire.
You will still have to drop Knee Panel below Steering Column.  2 - 7mm Screws
MO
