2006 dodge ram door trigger
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79587
Printed Date: April 06, 2026 at 4:05 PM
Topic: 2006 dodge ram door trigger
Posted By: dfiddy
Subject: 2006 dodge ram door trigger
Date Posted: June 25, 2006 at 2:07 AM
anyone wanna shave some time off there alarm/standard transmission starter install on these things just go directly to the dome light. Yellow/blue i think. It's a yellow/blue or YELLOW /GREEN. Test it. It works awesomely. Domelight doesn't come on after remote shutdown so it doesn't get pulsed. Also there is a little bit of a delay. Like 5 seconds or so (theatre lighting) but by the time you get out of the vehicle and are walking away theres enough time that it won't give you a open zone chirp from the siren. just thought i let those of you know who didn't know. Word. I'm out.
Posted By: jhull
Date Posted: June 25, 2006 at 1:31 PM
i use to use that wire... works good, but i found its a little easier just to get it right under the cluster. theres a harness its towards the passenger side of the bottom of the cluster it has that same wire...  saves a good 5 min from install : )
Posted By: dfiddy
Date Posted: June 27, 2006 at 2:26 AM
Nice, thanks for the new info mang!
