valet 561r
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79749
Printed Date: April 06, 2026 at 6:26 AM
Topic: valet 561r
Posted By: mobilecustoms
Subject: valet 561r
Date Posted: June 29, 2006 at 8:05 AM
on a velet 561r rs the car i am working on has a positive paarking light. the jumper in the module has pos or neg. the neg it says can be wired straight to the wire. is positigve the same way? it shows to wire a relay, but if it has the jumper should it be ok to wire the pos direct to the wie without a relay?
Posted By: swamprat323
Date Posted: June 29, 2006 at 8:52 AM
if your parkign light draws more then 10 amps switch over to negtive and use a relay wired for postive systems
Posted By: kgerry
Date Posted: June 29, 2006 at 12:40 PM
i use the white wire on postive direct to parking lights all the time with no issues.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
