viper 791xv?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79806
Printed Date: April 04, 2026 at 12:00 PM
Topic: viper 791xv?
Posted By: mikex1021
Subject: viper 791xv?
Date Posted: June 30, 2006 at 8:11 PM
siren keeps going off unless i open the trunk. the remote does not want to disarm the system, i just get a signal that the car is being tampered with.remote start does not work, no idea why, please help, its on a 94 integra gsr, if you know where each wire is hooked up to and what color please let me know?
Date Posted: June 30, 2006 at 8:13 PM
the car is a stick shift do i need to hook up the neutral safety switch, do i need to use any relays?
Posted By: captainzab
Date Posted: June 30, 2006 at 8:59 PM
Why would siren go off and stop when you open the trunk? Is it a bad remote? Are you asking to install this and need the vehichle diagram? If so, do a search on your vehichle. Also, plese be clear on what you are asking!!!
And if you are remote starting a manual transmision car, you must use a relay to bypass clutch using status wire.
Look at relay for extra info
Posted By: swamprat323
Date Posted: July 01, 2006 at 8:30 PM
is the siren got off a full vol or is it low, if low check the ground of the alarm and siren.
check the atenna unplug it an dplug it back in to see if it is the remotes, ahve you tired both of them, do any other bottons on the remote work.
