hornet 564t and 2004 toyota sequoia
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79918
Printed Date: April 02, 2026 at 4:43 PM
Topic: hornet 564t and 2004 toyota sequoia
Posted By: clock97
Subject: hornet 564t and 2004 toyota sequoia
Date Posted: July 04, 2006 at 11:08 AM
i have installed this alarm before with the remote start on my cavalier but i did some searching and it looks to be a little harder with the sequoia. do you need the bypass from bypasskit.com "TBKIV" to make the remote start work or is there another way?
Posted By: captainzab
Date Posted: July 04, 2006 at 9:52 PM
the 2004 sequoia does need a bypass, but the TBKIV requires you to give up a key. If you know there isn't a bypass kit that doesnt require you to give up a key to use, then purchase the TBKIV and throw in a key.
FYI, its the same thing as the 556U by directed or the 791 by bulldog.
I recommend getting whichever is cheapest because its gonna cost you to get a new key to replace the one you have to place in the bypass
Posted By: clock97
Date Posted: July 05, 2006 at 9:57 AM
thanks for the info, do i need a relay for the factory disarm or is it okay without one?
Date Posted: July 05, 2006 at 12:57 PM
no relay needed, just connect factory disarm wire to the vehichle
