Bonnet and boot pin switches not working
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80127
Printed Date: April 01, 2026 at 7:56 PM
Topic: Bonnet and boot pin switches not working
Posted By: davemonkey
Subject: Bonnet and boot pin switches not working
Date Posted: July 10, 2006 at 2:08 AM
The alarm is a Toad A101CL, i've tried touching the switch wires to earth but to no avail.
Wondering if anyone has any ideas before i take the alarm out to have a look.
Posted By: josh1979
Date Posted: July 10, 2006 at 7:37 AM
if i undestand the wire you have is a wire that triggers the  the alarm when a negative dood pin is triggerd and u can arm the alarm and ground (earth) this wire and the alarm does not go off?
if thats the case i say check and make sure the wire on the brain is looking for a negative trigger , check the wire right at the brain and at the end with a multi meter to see if it has continuity  (a break in it). if all checks out than u have a bad brain
bring back the rotary phone so i dont have to press 1 to proceed in english
Date Posted: July 12, 2006 at 2:07 AM
Sorry only just been able to get online. Yeah the pin switches are negative trigger.
I thought it was odd that both of the switches stopped working together! I'll check for a break in the wire asap.
Hope the alarm isn't knackered, it's not that old.
