viper 791xv activation wire?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80149
Printed Date: April 02, 2026 at 6:47 AM
Topic: viper 791xv activation wire?
Posted By: bigfoot286
Subject: viper 791xv activation wire?
Date Posted: July 10, 2006 at 9:24 PM
one question about it the H1/3 WHITE/ Blue remote start (-) activation wire. what exactly do the mean by it needs two negitive pulses? two just once or every time it goes to start? and would nutrule safty swich work for that? it is the only thing thta confuses me about the alarm everthing else i got. and if it helps its an 05 dodge stratus coupe
Posted By: JWorm
Date Posted: July 10, 2006 at 9:51 PM
Its not needed. Leave it alone.
Date Posted: July 10, 2006 at 10:26 PM
thats what i thought. but what would i do with it if i were to use it?
Posted By: captainzab
Date Posted: July 11, 2006 at 3:17 PM
you would use it if you had another alarm system that had a aux channel. By sending 2 consecutive pulse to this wire (from your alarm system with the aux channel) it will remote start
But since you have an alarm (791), no need
Learn something new everyday!
Posted By: extreme1
Date Posted: July 11, 2006 at 5:27 PM
if you had a DEI timer/temp module you would use the WHITE/ blue input.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
