how to reprogram karr remote?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80415
Printed Date: April 19, 2026 at 4:56 AM
Topic: how to reprogram karr remote?
Posted By: ben dover
Subject: how to reprogram karr remote?
Date Posted: July 17, 2006 at 7:55 PM
hi, i have an 05 corolla ce with a karr alarm system. i don't know what model it is but will check if i knew were to to look. the karr alarm was install by  the dealership with only the driver door locking and unlooking. so i add the rest of the door locks and to add it i had to disconnect the alarm from the plug (not the wires). i replug the alarm and now it dousn't work with my remotes. i think that it got rested and needs to be reprogram, cause when you honk two times the doors unlocks so the alarm is working, and also if i hold the valet botton behind the l.e.d. light the l.e.d. stay on like it on valet mode. well anyway i would like to know how to reprogram the remotes. and yes i have check and doble check the froum for answers but it didn't work for me so plase can someone help me. and thanks.
Posted By: Twelvoltz
Date Posted: July 17, 2006 at 9:58 PM
Try the instructions listed here.
Date Posted: July 18, 2006 at 4:57 PM
no i didn't work. is the valet switch behind the l.e.d. ? if not were is it? i press it three time and no honk. do i have to have the door open a la dei.? or close? thnaks.
Date Posted: July 19, 2006 at 4:28 PM
hey it work. the problem was that there was no ground to alarm. well i connected the ground and progamed it and now it works. thanks you soooooooooooooooooooo much.
