keypad under hood, oddball?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80453
Printed Date: April 05, 2026 at 9:56 AM
Topic: keypad under hood, oddball?
Posted By: skinner21
Subject: keypad under hood, oddball?
Date Posted: July 18, 2006 at 6:22 PM
I have shaved the doors on my car and installed door poppers and I want to put a keypad under the hood (it is an old car that you can get under the hood with out getting in the car) that would run on a secondary 12 volt gell cell battery so if I am ever locked out or my battery goes dead I will be able to key in a code and pop my doors open. I first thought of salvageing a keypad off of an older lincoln but then I would probably have to have some sort of bcm soooo I guess my question is do any of you guys that are in this business know of a key pad that would work. all I need it to do is switch 12 volts on by entering a code.
Posted By: mustangfoo
Date Posted: July 18, 2006 at 7:32 PM
Asianwolf has a starter kill keypad, maybe something like that, but do not I repeat DO NOT order from them!!!
Date Posted: July 18, 2006 at 7:45 PM
ok then tell me where to get one and when activated does a starter kill key pad send a 12 volt pulse or a ground pulse or what... I need to know how they work cause i am a rookie at this I just get ideas and sometimes they work and sometimes they dont
Posted By: dualsport
Date Posted: July 18, 2006 at 8:48 PM
Sounds like you're looking for a premade item, but
there's an IC chip that you can use to make your own keypad circuit pretty easily, combination would be hardwired. It has four lines that need to be keyed in sequence, but you can wire it with as many buttons as you like to make it impossible to crack, by wiring them to the reset line.
Have to look up the part number for it; I have a bunch stashed away when I used it for a starter kill circuit a long while ago.
Posted By: swamprat323
Date Posted: July 18, 2006 at 9:11 PM
just a though......... how about those small keypads liek ti unlock doors and such.
also check this out, thsi is for if you lock your keys in the car you just tap on your window with a code u make up an dit will unlock your doors.
here
Date Posted: July 18, 2006 at 9:13 PM
for a note.... i showed this to some one before, they said they did not liek it. he said what if some found out my code and they can steal my stero............Well one you dont tell any one that you have it, aslo you can change the code anythime you want.
Date Posted: July 18, 2006 at 9:35 PM
Neat idea. Seems like it might be difficult to hide from someone watching you though. Probably would be good for emergency use though, where you could change the code if there was anyone around to see you using it.
Posted By: Chris Luongo
Date Posted: July 18, 2006 at 9:39 PM
The keypad idea is a cool one, and it sounds like a fun project, but don't forget that there are other ways to do this.
One way would be to mount a magnetic reed switch (they're cheap) inside an exterior light, or against the window glass. Hide a magnet under the hood or under the car. Wire the reed switch so that when you pass the magnet over the "secret" spot, the door opens.
Date Posted: July 18, 2006 at 9:48 PM
i liek the reed switch, a lot cheapter then the tap magic thing.
Date Posted: July 18, 2006 at 10:32 PM
dualsport wrote:
Sounds like you're looking for a premade item, but there's an IC chip that you can use to make your own keypad circuit pretty easily, combination would be hardwired. It has four lines that need to be keyed in sequence, but you can wire it with as many buttons as you like to make it impossible to crack, by wiring them to the reset line. Have to look up the part number for it; I have a bunch stashed away when I used it for a starter kill circuit a long while ago.
thanks any information you can get me on it would be great I like to make things from scratch
Date Posted: July 18, 2006 at 11:40 PM
It's pretty simple with this LS7220 chip
Here's the datasheet; shows the schematic for hooking everything up-
LS7220
possible source (enter LS7220).
