CompuStar 1WAM-A ’99 BMW M3
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80704
Printed Date: March 28, 2026 at 4:15 PM
Topic: CompuStar 1WAM-A ’99 BMW M3
Posted By: dgm727
Subject: CompuStar 1WAM-A ’99 BMW M3
Date Posted: July 24, 2006 at 8:24 PM
I just tried installing a Compustar 1WAM-A in my '99 BMW M3 Convertible.
I am unable to program the remotes by turning the ignition on and off 5 times then depressing the lock button on the remotes.
It seems I was required to wire a diode on the parking light - output, otherwise when you pushed the hazard light switch in the car the lights will continue to flash even thought the button is up.
Here is how I wired my car:
Alarm Module        Factory BMW Alarm Pre-wired Harness
CN1
Siren +                    BLACK/ Blue
Parking Light +      N/A
Constant 12V        RED / Grey / YELLOW
Ground                    BROWN / Orange
CN2
Parking Lights -      Blue/GREEN/ YELLOW
Horn Output -          N/A
Aux 1 -                      N/A
Aux 2 -                      N/A
Starter Kill -             N/A
Ignition Sensing + Violet/White
Dome Light -           N/A
Rearm Output -      N/A
Disarm Output -      N/A
CN3
Hood Pin -                  Violet/GREEN/ YELLOW
Trunk Pin -                  BROWN / White
Door Pin -                    BROWN / Grey / YELLOW Drv side
Door Pin +                   N/A
Optional 2nd Stage - N/A
Optional 1st Stage -   BROWN / Blue / YELLOW Pax side
CN4
None                           N/A
Trunk Output -           N/A
2nd Pulse Unlock -  N/A
Unlock Output -         Blue/RED / Yellow via relay to switch pulse to +
Lock Output -             WHITE/ RED / Yellow via relay to switch pulse to +
The remaining CN5, CN6, CN7 and CN8 on the alarm module use the alarm pre-made molexes for LED, shock sensor, antenna, and paging(not used).
Posted By: dgm727
Date Posted: July 30, 2006 at 10:16 AM
Any suggestions?
Posted By: Velocity Motors
Date Posted: July 30, 2006 at 5:03 PM
IGNITION sensing should be GREEN at the ignition harness. Make sure that this wire sees 12 volt switched otherwise the unit will not program. Also, you MUST toggle the ignition 5 times within 3 seocnds and press the LOCK button within this 3 second window otherwise it will not program. The wire you have the IGNITION  sensing may be right but your timing may be wrong.
