530T drivers window down, 04 impreza
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80722
Printed Date: March 29, 2026 at 2:00 AM
Topic: 530T drivers window down, 04 impreza
Posted By: w000rd
Subject: 530T drivers window down, 04 impreza
Date Posted: July 25, 2006 at 4:25 AM
I have a 04 sti.
My drivers window, the one touch, only rolls down my window 2 inches (85% of the time.). Then I need to push the button again to make it roll down all the way. The shop (this is a good shop locally) says it's because of the OEM one touch circuit. It makes it stop. Going up is no problem. Is there anyway around this? If I knew what wires to hook up, I could do it.
FYI: When I roll my windows down with the remote, it goes down how it is suppose to about 75% of the time. The other 25%, the drivers side window only goes down 2 inches, then I have to push the remote button again to get it all the way down.
All of the other windows work perfectly and are controlled by the drivers switches.
Posted By: captainzab
Date Posted: July 25, 2006 at 10:45 AM
To vent the window 2" press the aux button. To roll down, press aux button for 3 sec. I think your not pressing it long enough.
Since This is onyl occuring on the driver side where you have one-touch, make sure the connection is make between the module and the motor. Also check the dip switch and change resistance if you think that might be the prob.
Posted By: w000rd
Date Posted: July 26, 2006 at 3:17 AM
Oh, maybe I wasn't clear. It doesn't roll down when I push on the driver's window switch. Not from the remote.
