06 murano wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80744
Printed Date: March 29, 2026 at 6:48 AM
Topic: 06 murano wiring diagram
Posted By: tbo1
Subject: 06 murano wiring diagram
Date Posted: July 25, 2006 at 1:27 PM
hi everyone, i'm looking for a wiring diagram to install an alarm w/remote start on a 06 nissan murano. any help would be greatly appreciated. thank you in advance.
tbo
Posted By: 12voltmaster
Date Posted: July 25, 2006 at 3:15 PM
tbo1
Next time go to in this section : Vehicle Information Requests in this FORUM
Battery 1    Green        Ignition Harness   Positive
Ignition 1   BLACK/ Red (Small)
Starter 1    BLACK/ Red (Large)
Starter 2    BLACK / YELLOW
Accessory 1 WHITE/ Blue
Accessory 2 Red
Parklights Positive RED / Blue (4) Gray Conn. Near E-Brake in Drivers Kick Pannel Positive
Brake Lights RED / Green Gray Conn. Near E-Brake in Drivers Kick Pannel Positive
Tach Yellow Or White (3) At PCM Module (Glove Compartment) 2 Cyl
Lock Behind BCM (1) Behind BCM Pin 13 at 40 Pins White Conn (2) Negative
Unlock Behind BCM (1) Behind BCM Pin 14 at 40 Pins White Conn (2) Negative
Disarm Behind BCM (5) Behind BCM Pin 13 at 40 Pins White Conn (2) Negative
Rearming Behind BCM Behind BCM Pin 14 at 40 Pins White Conn (2) Negative
Dome Sensor Red and RED / White Behind BCM Pin 7 at 15 Pins Black Conn (2) Negative
Trunk Pin PURPLE / White Behind BCM Pin 3 at 15 Pins White Conn (2) Negative
Enjoy !!
Posted By: tbo1
Date Posted: July 25, 2006 at 7:09 PM
thank you master, i didn't know there were such a section on this site.
tbo
