04 toyota sequoia door triggers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80821
Printed Date: March 30, 2026 at 8:03 AM
Topic: 04 toyota sequoia door triggers
Posted By: clock97
Subject: 04 toyota sequoia door triggers
Date Posted: July 27, 2006 at 8:56 AM
i have the 564t by dei and i've diode each door trigger and the alarm only goes off  when you close the door, i was wondering how would i reverse this problem. thanks
Posted By: Chris Luongo
Date Posted: July 27, 2006 at 5:25 PM
Which alarm input are you wired to.........purple positive, or green negative?
I usually don't bother with diodes.........the courtesly light around the ignition cylinder catches all five doors.
