viper 550hf and 600 esp on one remote?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80989
Printed Date: May 05, 2026 at 12:35 AM
Topic: viper 550hf and 600 esp on one remote?
Posted By: erock198
Subject: viper 550hf and 600 esp on one remote?
Date Posted: July 31, 2006 at 1:45 AM
I have a 550hf in my volvo 740 and a 600 esp in my 86 IROC-Z. I have button one on my 476T remote for arm and button 3 for start. Can I program button for to lock and unlock my 600esp or am I stuck using 2 remotes?
Posted By: swamprat323
Date Posted: July 31, 2006 at 10:06 AM
I dont see any 600 ESP looking at directed transmitter cross referance guide.
try it and see what happens, not goign to screw things up.
https://directed.com/guides/transref.asp
Posted By: captainzab
Date Posted: July 31, 2006 at 12:52 PM
i dont got the diagram for both manual, but im pretty sure both remote has a green LED. So the green led remote are capable of memorizing up to 2 different vehichle.
If you have the manual, go ahead and program the remote to the alarm.
Posted By: erock198
Date Posted: July 31, 2006 at 1:14 PM
Yeah both have green but can I program any button to do any function? I was not sure why it was not responding when I tried to program it function 8?
Date Posted: July 31, 2006 at 3:19 PM
im not sure if you are trying to program each button individually, or you are doing the auto-learn (default).
But if you are doing it individually and it doesnt accept, try deleting all transmitter to the alarm and try again.
usually, the alarm can handle up to 4 different remote (im not sure if the brain thinks that an individual command is an individual remote or not)
Posted By: erock198
Date Posted: July 31, 2006 at 3:24 PM
ok My routine is as in the manual. with the door open and the key on, I hit the valet button 8 times then I stop a second then one time and hold it. I do not hear the long chirp though. I don't get to the point when I hold the button then press the transmitter button. I programmed a different remote using button 1 but want this one for both cars so trying button 4 for arm/disarm/panic.
Date Posted: August 02, 2006 at 10:37 AM
the system may be lock buy the bitwriter so yuo cant program new remotes. usally if try to enter program mode and here the long chirp then it is block by the bitwritter.
aslo i dont belive you can do auto learn.
have to do chanel by chanel, if nto you be diaarmign etc both cars at once.
Posted By: erock198
Date Posted: August 02, 2006 at 9:34 PM
Ok yeah but I did autolearn on another remote. Is there a 2 remote max?
Date Posted: August 02, 2006 at 9:50 PM
should be 4 remotes it can learn if try to learn more it deleats the first one. waht are the part numbers on back of the remotes look them up on direced list that i posted on the 2nd post
Posted By: erock198
Date Posted: August 02, 2006 at 11:41 PM
the one I have for the 600esp is a 475. I have 2 of them. The one I use with my 550hf says 476t on it.
Posted By: erock198
Date Posted: August 02, 2006 at 11:43 PM
Yeah they both actually say 475 on them EZSDEI475
Date Posted: August 03, 2006 at 12:15 PM
for both system they have the same FCC id number then they can be 1 remote for both cars. but u have to do ch by ch for all cars.
