speed, tach & illumination not working
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81281
Printed Date: April 18, 2026 at 8:31 AM
Topic: speed, tach & illumination not working
Posted By: kaipo777
Subject: speed, tach & illumination not working
Date Posted: August 06, 2006 at 7:18 PM
Howzit,
I just installed a scytek lcd alarm into a 90 prelude, basic features only: door trigger, trunk trigger, dome light, starter kill.  The thing is the alarm works but now the speedometer, tachometer and illumination doesn't work.  Also, the clock still works but is only visible if you press the button on it.
Of course, i already checked all the fuses under the dash and hood, all good.
Any ideas ...
Thanks in advance,
Kaipo :)
Posted By: swamprat323
Date Posted: August 06, 2006 at 7:33 PM
doulbe check the fuses, may have blown the MAIN igntion one, it be a big fuse.
when you did the starter kill make sure the harness is plug in.
Posted By: kaipo777
Date Posted: August 06, 2006 at 7:39 PM
I checked all the ATC fuses under the dash and hood and i'm just wondering if the car would still power up and run if the ignition fuse was blown? >
Date Posted: August 06, 2006 at 8:17 PM
i dont think it would start, im not sure on that. were ddi you make your conections, did you test the wires with ameter or a test light, you could fired one of the computers. may have a trip to the dealer
Date Posted: August 06, 2006 at 8:19 PM
any were you tap into make suer all wires plugs are plug in all the way.
Posted By: kaipo777
Date Posted: August 06, 2006 at 10:55 PM
I used a dig multi-me to test all the connections made and troubleshooting, also, the car is currently running and the alarm is working.
I looked around all day yesterday for loose connections but i still think it's possible i may have overlooked something.  I'm assuming though, that my connections are ok if the car and alarm are working. What i mean by working is the alarm triggers, starter kill, parking light flash, dome light and programming works and the car starts and functions (parking lights, headlights, radio, turn signals and it drives,etc.)
I'm currently planning on taking it to an electric shop. (Sucks man, my first install failure ... anyways.  I'm sure it won't be the last c**k-up.)
By the way i'm not sure why but the car owner said that the seatbelt lightis opposite ... goes on when the belt is fastened and off when it isn't.  Damn, this car's been chaos, the bad kind of chaos.
Date Posted: August 06, 2006 at 11:01 PM
you had to blown a fuse may jsut want to chenk the fuses with a meter not by lookign at them, soem case is look goo dbut it is bad, also chack realys
