2006 Chev Uplander wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81456
Printed Date: April 05, 2026 at 8:27 PM
Topic: 2006 Chev Uplander wiring
Posted By: codybrown
Subject: 2006 Chev Uplander wiring
Date Posted: August 10, 2006 at 4:28 PM
I am Looking for the 12volt and ignition wiring for a Chev Uplander.
Posted By: josh1979
Date Posted: August 10, 2006 at 4:58 PM
12voltsred or RED / black + battery or fuse box
Starteryellow + ign harness or BCM, C1, pin 21
Notes: The BCM is to the left of the steering column. C1 is a 52 pin black plug. C2 is a 52 pin black plug. C3 is a 18 pin black plug.
Second StarterN/A
Ignitionpink + ign harness or BCM, C1, pin 22
Second IgnitionN/A
Third IgnitionN/A
Accessorybrown + ign harness or BCM, C1, pin 23
Second AccessoryN/A
Keysenselt. green - ign harness or BCM, C1, pin 40
Power LockORANGE / black or pink/black - BCM, C2, pin 2
Power UnlockORANGE / black - BCM, C2, pin 11
Lock Motorgray 5wiBCM, C2, pin 52
Unlock Motortan 5wiBCM, C2, pin 46
Parking Lights+brown + fuse box or pass kick, harn. to rear
Parking Lights-BROWN / white - switch or BCM, C3, pin 8
Hazardstan - switch or BCM, C3, pin 16
Turn Signal(L)lt. blue/white (F), yellow (R) + BCM, C1, pin 41 and C2, pin 43
Turn Signal(R)dk. blu/wht (F), dk. green (R) + BCM, C1, pin 42 and C2, pin 48
Reverse Lightlt. green + BCM, C2, pin 42
Door Triggersee notes - BCM, C2
Notes: The LF door is gray/black in pin 26. The RF door is tan/white in pin 17. The LR door is lt. blue/black in pin 7. The RR door is lt. GREEN/ black in pin 5. Use all four wires and diode isolate each.
Dome Supervisiongray/black + BCM, C1, pin 43
Trunk/Hatch Pindk. green - BCM, C2, pin 3
Hood Pinpink/black - pin switch or BCM, C1, pin 26
Trunk/Hatch ReleaseN/A
Power Sliding Doorlt blue/black (L), lt blue (R) - pass. side B pillar, blk 23 pin plug
Factory Alarm Armarms on lock with door open
Factory Alarm Disarmpurple - BCM, C2, pin 24
Disarm No Unlockwith ignition and Passkey
TachometerNOT pink ac any fuel injector
Wait to startN/A
Brake Wirewhite + BCM, C2, pin 30
Parking Brakelt. blue - switch or BCM, C2, pin 9
Horn Triggertan - switch or BCM, C1, pin 4
Memory Seat 1white - memory module under seat, gray plug
Memory Seat 2purple - memory module under seat, gray plug
Memory Seat 3N/A -
posted_image
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
PASS-Key III
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
posted_image
Smart Starter Kill Relays:Relay Type:
Crank Relay
Engine compartment fusebox, Driver side
Part #: 6402A
bring back the rotary phone so i dont have to press 1 to proceed in english
