Remote Starter - Tach Wire?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8148
Printed Date: May 19, 2026 at 9:24 AM
Topic: Remote Starter - Tach Wire?
Posted By: Ron_toolman
Subject: Remote Starter - Tach Wire?
Date Posted: January 14, 2003 at 5:47 PM
Hello, I have a CT-3160M Pro Start from C.Tire installed last year, it worked for awhile then I just turned it off, it's installed on a 2000 Sunfire Manual Trans. now when I try to re-program it, it's telling me by the lights staying on that it's not a good Tach Sensor, the diagram tells me to use the White wire on the 2000 Sunfire but this won't work, is there another tach wire I can use? Thanks Ron
Posted By: mark2003
Date Posted: January 14, 2003 at 5:54 PM
That tach should definitely work if you are right at the coil, maybe you should check your connections or there may be something wrong with the remote.
Posted By: auex
Date Posted: January 14, 2003 at 6:43 PM
You should probably redo the connection, preferably soldered since it is under the hood, and go back through any tach programming the alarm may have.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Velocity Motors
Date Posted: January 14, 2003 at 8:44 PM
If the WHITE wire doesn't work, try the PURPLE / WHITE wire, but the WHITE wire is usually the cleaner of the two wires as far as AC signal is concerned.
------------- Jeff
