Adding a Alarm to a R/S Keyless Entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81505
Printed Date: April 05, 2026 at 12:29 AM
Topic: Adding a Alarm to a R/S Keyless Entry
Posted By: Trav3D1
Subject: Adding a Alarm to a R/S Keyless Entry
Date Posted: August 11, 2006 at 7:59 PM
I have a 2002 Chevy Trailblazer that has a Audiovox Pursuit PRO 9275T remote start / keyless entry installed already. The customer is interested in adding an alarm (specifically a DEI Hornet 740T). What is the best way to add the alarm so the customer does not have 2 seperate transmitters to control both systems? I have done this before on DEI to DEI products, but never a Audiovox to DEI product. ------------- Trav
Posted By: swamprat323
Date Posted: August 11, 2006 at 8:30 PM
does the audiovox have a remote start activate input. if so just use an aux ch on the hornet to control the audiovox RS. then no need to sue the audioovx remotes.
Date Posted: August 11, 2006 at 8:36 PM
just found the install guide for it. yes it has an external input. dark blue/black wire in the 3 pin input/output harness, needs a gound pulse.
Posted By: bmwpwner
Date Posted: August 11, 2006 at 10:40 PM
yea the input trigger would work for the remote start but you will still have to rewire the hornet to do the lock/unlock rather than the audiovox. i think it would probably be more feasible to just get an all in one alarm/keyless/remote start. but either way the majority of the wiring is already been found so i guess the input trigger wouldn't be to bad as long as you have enough room for the extra brain under the dash. good luck.
------------- "I cannot teach anybody anything, I can only make them think."
-Socrates-
Posted By: bmwpwner
Date Posted: August 11, 2006 at 11:40 PM
yea you would definitely have to use the new alarm's lock and unlock to control that portion and use the existing RS/keyless as a RS only. that way you can use the input trigger to the RS to activate it and everything else would be controlled and monitored thru the new alarm.
-Socrates-
Posted By: Chris Luongo
Date Posted: August 12, 2006 at 7:33 AM
The best way for the customer would be to install a "keyless upgrade" alarm like an Audiovox PRO-9232A, DEI Hornet 700T/Automate AM1, or similar.
That way, when they use the Audiovox remote to lock or unlock, it'll also arm or disarm the alarm...simple.
swamprat323's method would also work----use the new alarm's trunk-pop output to trigger the Audiovox's blue/black start activation input............but unless the alarm has a long-range, windshield-mounted antenna, the customer might not be happy with the range.
If you are an Audiovox dealer, or have access to their product, many of the plugs from the PRO-9275T remote starter, and the PRO-9775T/Prestige APS-786T are compatible............the main ignition wires, antenna, and doorlocks would plug right in.......there would be just a few wires you'd have to cut and re-splice (ground, brake, parking lights, tach)..........and then move on and connect your door trigger, shock sensor, starter kill, and LED.
