Door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81568
Printed Date: April 03, 2026 at 1:42 PM
Topic: Door locks
Posted By: ntfday
Subject: Door locks
Date Posted: August 13, 2006 at 11:50 AM
I have a '91 Dodge Dakota that I installed a Ultrastart 2250 security system in. I wired the door locks using their 5/wire reverse polarity door lock diagram which uses 2 relays. The doors locks do not work even from the factory switches on the door. Did I wire it wrong and could someone please help?
Not Fade Away
The easiest road is usually the last one sought
Posted By: KarTuneMan
Date Posted: August 13, 2006 at 5:45 PM
Yes you wired it wrong....if it worked BEFORE you got in there....yup.
ORANGE / purple for lock, pink/purple for unlock.
posted_image
The switch side will still operate after cutting the wire....thats how you know you have the correct side of the wire!
Posted By: ntfday
Date Posted: August 13, 2006 at 6:52 PM
I cut the orange and pink wires. Are you saying I need to cut ORANGE / purple and pink/purple wires instead?
Not Fade Away
