06 Lucerne bypass module
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81608
Printed Date: April 03, 2026 at 12:30 AM
Topic: 06 Lucerne bypass module
Posted By: prdjr165
Subject: 06 Lucerne bypass module
Date Posted: August 14, 2006 at 12:11 PM
Anyone know which bypass module to use-(GMSL)or(GMDL-BP)?
Posted By: sparkie
Date Posted: August 14, 2006 at 4:53 PM
Neither one will work. Go to bypasskit.com and check out the two modules for that car. They have a search function for the year make and model. One does the theft/immobilzer interface and the other does the keyless/alarm interface.
sparky
Posted By: NowYaKnow
Date Posted: August 15, 2006 at 6:11 AM
Key in the box.. I would pickup a module to do the locks though.
Mike
Posted By: sparkie
Date Posted: August 15, 2006 at 7:00 PM
The Lucernce is similar to the Impala and uses a hybrid Passlock/Passkey III system. You need to use the two modules I listed and you won't have any problems. The key in the box method won't work unless you also interface with the Passlock/starting circuit.
sparky
Date Posted: August 16, 2006 at 10:25 PM
You only need more hookups if your modules ACC wire doesn't fire up before the IGN wire. In which case you can use the following diagram along with a key in the box on the '04+ Malibu/G6, and the '06 Lucernce/Impala. If your modules ACC does come on before the IGN, a key in the box is all that you need.
https://www.installz.com/docs/2004plusgm.gif
Not as bad as it looks plus every connection can be done while you are prepping your module. Any questions just ask,
Mike
Posted By: prdjr165
Date Posted: August 17, 2006 at 6:03 AM
Thanks for all of your responses!I ordered the bypass module from bypasskit.com,hopefully it will work!I'LL KEEP YOU POSTED.
