1998 dodge ram door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=82606
Printed Date: April 17, 2026 at 4:14 PM
Topic: 1998 dodge ram door locks
Posted By: dragster
Subject: 1998 dodge ram door locks
Date Posted: September 07, 2006 at 8:09 PM
I installed a Viper 791 in a 1998 dodge ram. Everything works great except the drivers side door lock does not activate with the alarm. The passenger side works as it should. If I pull the relays out and go back to stock, the switch in the door activates both sides. I have the locks wired in the 3/5 relay setup and grabbed the factory wires inside the kick, just after they come out of the door. Any help would be appreciated.
Posted By: swamprat323
Date Posted: September 07, 2006 at 9:56 PM
try the driver door as a 5 wire. im not sure waht year the truck was. it was a while back, i had to wire both as 5 wire not 3/5
Posted By: dragster
Date Posted: September 08, 2006 at 6:22 AM
I tried the same door lock wires as a 5 wire when I was at it originally and that gave no responce. Niether door locked or unlocked that way. Thanks for the idea though.
