truck camper alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=82992
Printed Date: April 09, 2026 at 3:44 PM
Topic: truck camper alarm
Posted By: royxxx01
Subject: truck camper alarm
Date Posted: September 17, 2006 at 1:02 PM
I have a 2004 gmc truck on which i carry a slide-in camper. This is a self-contained camper which sits in the bed of the truck. I would like to install a proximity type alarm that would protect the camper. Would this work? I would like to install the alarm myself. I have never installed an alarm before but I am knowledegble in the field of electronics. The pictures of the alarms i have looked at on the internet look like they have connectors made to hook into existing car circuitry. Do they come with diagrams so that i can figure out how to wrie them in an application like mine which is not standard?
Posted By: bellsracer
Date Posted: September 18, 2006 at 6:14 AM
This is possible, but I"m not going to lie to you, it may not be easy if your camper comes on and off your truck once and a while, but that will depend on the model of alarm you put on.
Secondly, we don't remcommend putting on a proximity alarm. As the temperatures around the camper change so does the sensitivity of the alarm and that can trigger false alarms. We recommend getting an alarm that can use multiple triggers and use glass sensors and magnetic reed triggers. The design of most campers means that shock sensors will be kind of useless. Mount the glass sensor somewhere high and in the middle of the camper. If there is a particular window that is big enough for someone to get into easily, it would be beneficial to tilt the microphone slightly towards the window. Apply the reed sensors along the windows and doors where it would be hard to get to.
The alarm you choose will be one that doesn't trigger when you cut the power to it. That way you can disconnect your camper's power without triggering the alarm. No particular models come to mind at the moment, but one of our guys might know of one that could work. It'll be a basic one. You won't need lock/unlcok features (unless you want to add power locks, but not really needed) or an LCD receiver (which drains the battery in your fob every couple of months). Just an alarm that waits for a trigger then sets the alarm off.
Or what about this? Buy those battery powered window/door alarms that you can buy for like 6 for $20, You'll have to recharge/replace the batteries every 6 months (or sooner depending on use and circumstances) but you won't have to go through a bunch of wiring.
Another thought that came to mind was adding a 12v battery such as a motorcycle battery or lawnmower battery and tapping off that for the alarm. Then mount a small (like 1.5 watts) solar panel to the roof to keep the battery charged for the alarm. Most decent quality panels will have an isolator built into them so it should not interfere with the function of the alarm.
Hope this give you better direction for what to do or look for. PM if you have any more questions.
Good Luck!
