RS Stopped Working
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83003
Printed Date: April 10, 2026 at 1:30 AM
Topic: RS Stopped Working
Posted By: jones100001
Subject: RS Stopped Working
Date Posted: September 17, 2006 at 4:21 PM
I replaced my car key on the remote starter (Viper 791xv) and now my car won't remote start. Car turns and starts but immediately dies. Any suggestions on what I should check for?
Posted By: KarTuneMan
Date Posted: September 17, 2006 at 4:23 PM
year, make, model,.....did you use the standard "key in the box" bypass? if so the new key being programmed, bumped the old key out.
Date Posted: September 17, 2006 at 4:35 PM
01 maxima. So just wait until the other key is being programmed w/ the remote starter?
Date Posted: September 17, 2006 at 5:34 PM
The one in the "box" needs to be re-programmed.....it's useless rite now. All the old keys need to be programmed when you have a new one programmed. Take the key out of the box....and ask the stealership, if they will be real nice and do you a favor, and reprogram all the keys. -------------
Date Posted: September 17, 2006 at 6:39 PM
what if I get a different remote starter? would I have to program my keys or could I just use my old keys?
Posted By: Chris Luongo
Date Posted: September 17, 2006 at 11:07 PM
Yeah, that's the deal with Nissans..... you must have ALL the keys available when programming.
Like Kartuneman says, the best way would probably be to remove the key that's in the box, and then hand all of them to the Nissan dealer for programming.
You can also tell them to simply do their normal programming........ at the time they're supposed to turn the ignition on with that other key, just activate the remote start instead.........when they want the ignition off, hit the brake.
This usually works, but some of the Nissan techs will have some trouble doing it. Also, DEI-brand remote starts being cranking the starter almost immediately after the ignition comes on, which can be a problem.
Date Posted: September 18, 2006 at 3:47 PM
Does this mean that I can't use the remote starter if I install it on a different car?
Date Posted: September 18, 2006 at 4:39 PM
No, it's just one of your spare Nissan keys inside the bypass box mounted under the dash.
Most likely, the remote starter is fine, it's just the key that needs to be reprogrammed.
Pulling the remote start out of your car and installing it in another car is completely possible, although often it's not worth it.
All of the wiring has already been cut to length to fit your car, wrapped up in tape, etcetera.
The cost for labor to remove it from the old car, clean up and straighten out all the wires......extend some of them if necessary.....and install that in the new car.......usually adds up to almost the cost of just getting a new one installed.
Date Posted: September 18, 2006 at 4:50 PM
do you know approximately how much programming the keys at the dealership cost?
