06 sierra activation
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83133
Printed Date: May 12, 2026 at 9:04 PM
Topic: 06 sierra activation
Posted By: joehonee
Subject: 06 sierra activation
Date Posted: September 20, 2006 at 6:33 AM
I am adding a Valet 561T add on remote starter to an 06 GMC Sierra. I don't know if I am loosing my mind but I cannot determine how to activate the starter. I plan on using the unlock wire because if I use the lock wire I will sound the horn of the truck every morning. Does anyone know where to find the unlock pulse wire in the BCM?
Posted By: Mike M2
Date Posted: September 20, 2006 at 6:37 AM
You won't find the first unlock in the truck, gotta go in the drivers door. Second unlock can be found in the passenger end of dash cover. Also found in the drivers kick on 4 doors...
Mike M2
Tech Manager
CS Dealer Services
Posted By: joehonee
Date Posted: September 20, 2006 at 8:22 AM
Im sorry "first" and "second" unlock. Also do I need to isolate or reverse the signal with a relay?
