'01 Civic Wiring Diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8317
Printed Date: April 04, 2026 at 8:40 AM
Topic: '01 Civic Wiring Diagram
Posted By: haemphyst
Subject: '01 Civic Wiring Diagram
Date Posted: January 19, 2003 at 1:02 AM
I keep seeing all of these posts and answers regarding the wiring diagram for the '02 Civic, but I have an '01...  Are they the same?  Any help would be appreciated.
Posted By: 10nesne1
Date Posted: January 19, 2003 at 1:09 AM
YEAR: 2002  MAKE: Honda  MODEL: Civic  STYLE:
|       ITEM          |     WIRE COLOR      |POL |       WIRE LOCATION        |
|                 12V |white                | +  |ignition harness            |
|             STARTER |BLACK/ white          | +  |ignition harness            |
|            IGNITION |BLACK / YELLOW         | +  |ignition harness            |
|           ACCESSORY |BLACK/ red            | +  |ignition harness            |
|    SECOND ACCESSORY |WHITE/ red            | +  |ignition harness            |
|          POWER LOCK |WHITE/ blue           | -  |gray plug above drivers kick|
|        POWER UNLOCK |WHITE/ green          | -  |gray plug above drivers kick|
|          LOCK MOTOR |yellow/black         |    |back of the fusebox *3      |
|        UNLOCK MOTOR |YELLOW /GREEN         |    |back of the fusebox *3      |
|       DISARM DEFEAT |yellow               |    |back of the fusebox *3      |
|    PARKING LIGHTS + |RED / black            |    |back of the fusebox         |
|    PARKING LIGHTS - |blue                 |    |factory alarm plug *1       |
|          HEADLIGHTS |blue/red             | -  |headlight switch            |
|        DOOR TRIGGER |*2                   | -  |factory alarm plug *1       |
|    DOME SUPERVISION |comes on with unlock |    |                            |
|     TRUNK/HATCH PIN |red                  | -  |factory alarm plug *1       |
|          TACHOMETER |blue                 |    |test connector *4           |
|         SPEED SENSE |WHITE/ green          |    |PCM *5                      |
|          BRAKE WIRE |WHITE/ black          | +  |brake pedal switch          |
|        HORN TRIGGER |orange               | -  |steering column             |
|              WIPERS |blue (L), blu/yel(H) | -  |steering column             |
|   LF WINDOW UP/DOWN |RED / blk - RED / yel    | A  |drivers window switch       |
|   RF WINDOW UP/DOWN |blu/red - blu/wht    | A  |drivers kick panel          |
|   LR WINDOW UP/DOWN |brn/wht - brown      | A  |drivers kick panel          |
|   RR WINDOW UP/DOWN |blu/org - brn/yel    | A  |drivers kick panel          |
|           RADIO 12V |WHITE/ red            | +  |radio                       |
|        RADIO GROUND |black                | -  |radio                       |
|        RADIO SWITCH |yellow/red           | +  |radio                       |
|    RADIO ILLUMINATE |RED / black            | +  |radio                       |
|       POWER ANTENNA |                     |    |                            |
|          LF SPEAKER |grn/blk - lt green   |    |radio                       |
|          RF SPEAKER |grn/yel - gry/red    |    |radio                       |
|          LR SPEAKER |blu/wht - blu/blk    |    |radio                       |
|          RR SPEAKER |pink - blu/yel       |    |radio                       |
NOTES:
NOTE:  This vehicle has an immobilizer system that needs to be bypassed
when adding remote start.  Use DEI part number 555I or 555U.
*1 The factory alarm plug is a green plug above the drivers kick panel.
*2 The drivers door trigger is green, front passenger door trigger is lt.
GREEN/ red, and the rear door trigger is GREEN / WHITE.
*3 In the top left plug.
*4 It is a 2 pin plug to the passenger side of the battery.
*5 The PCM is behind the glove box. The vss is in a connector A (31 pins),
pin 18. The vss is also blue/white at the cruise control module to the
left of the steering column.
