1991 Lumina R/S problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83433
Printed Date: April 18, 2026 at 2:16 PM
Topic: 1991 Lumina R/S problem
Posted By: dea,can
Subject: 1991 Lumina R/S problem
Date Posted: September 27, 2006 at 7:05 PM
Hi there have done a few of these cars the thing is that it will not  start when it sits over night  have tryed autostart,blackwidow,this car is from hell ,when u start with the key it will start but not by remote only after it warms up  u can use the remote and its not that cold yet .
dragon
Posted By: jason quarters
Date Posted: September 27, 2006 at 8:51 PM
U need to have a valid tach source to make them start all the time.  Does the car roll over but not start? If so check tach, and crank time, some are adjustable.
its true!
Posted By: caraudio904
Date Posted: September 28, 2006 at 12:13 AM
I use to have a buick that did the same thing. I was using tachless on it, but I just extended the crank time and it worked
Southern Stylez
Jacksonville, FL 32218
Posted By: dea,can
Date Posted: September 28, 2006 at 12:40 AM
i will try that my dwell meter show good tach use the same wire on others cars the same make  but hey i will try a longer crank time and go from there thanks.
dragon
Posted By: customak47
Date Posted: September 29, 2006 at 4:28 PM
just hook up a tach wire. it will work just fine. dbl
My rifle is my friend...
Posted By: dea,can
Date Posted: October 19, 2006 at 3:29 AM
I asked this question before The thing is if the car sits for 2-3 hrs or overnight car will not remotely start but it will start with the key let the car run for about 5mins then turn off car then push the remote start button car will start  then when its sits again like i said could a bad battery do this going to meter it @ the battery she if the volts drop below 11 volts anyother input  done a few of these cars in the pass.
dragon
Posted By: Twelvoltz
Date Posted: October 19, 2006 at 6:41 AM
Load test the battery, sounds like it is the cause of your problems.
