2006 4Runner Rear Glass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83558
Printed Date: March 24, 2026 at 1:22 AM
Topic: 2006 4Runner Rear Glass
Posted By: Memphisman
Subject: 2006 4Runner Rear Glass
Date Posted: September 30, 2006 at 7:55 PM
Is there anyplace else to tap into the rear power glass controls other than the rear hatch lid itself?
Posted By: KarTuneMan
Date Posted: September 30, 2006 at 8:10 PM
In the BECU middle conector there are 3 wires. to lower the window, use a relay and close contact between the blk/blue, and blk / YELLOW. To raise the window, use a relay and close contact between the yellow/red, and the BLACK / YELLOW. Don't ask me how to wire the relays, someone else here will have to help you with that part. This is how its written in the astrochart, no picture either.
Posted By: Mike M2
Date Posted: October 02, 2006 at 9:57 PM
I would like to know of another way, but what i do is use 2 relays. You can get the up and down wires right off the back of the dash switch as a positive. The 2nd realy is to flip the second ignition on to make the switch work....
Mike M2
Tech Manager
CS Dealer Services
