Looking for different tach wire, 06 F150
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83607
Printed Date: March 26, 2026 at 4:06 AM
Topic: Looking for different tach wire, 06 F150
Posted By: dasbogie
Subject: Looking for different tach wire, 06 F150
Date Posted: October 02, 2006 at 12:44 PM
I've installed a python 881xp in an 06 F150. I tapped into a fuel injector wire as stated in another post on this forum. I can't get the brain to learn the tach signal. I even tried changing the jumper setting. How long does one have to sit there and hold in the valet button to learn the signal? Does anyone have another suggestion for a different wire to try? Thanks
Posted By: jclaar
Date Posted: October 02, 2006 at 12:50 PM
Double check to make sure you have the UNcommon inj. wire. It should only take about 3 seconds for it to learn the tach. If it doesn't, you are either tapped into the wrong wire or you're not entering the programming sequence correctly. I don't know where else to get the tach. DEI usually posts the easiest loaction. The inj. wire is usually a last resort for tach signal so I doubt you can get it anywhere else.
Posted By: swamprat323
Date Posted: October 02, 2006 at 1:00 PM
what kind of connection are you using. make sure it is a good one.
Posted By: dasbogie
Date Posted: October 02, 2006 at 1:10 PM
Red is the common color I tapped into the tan/black.
Posted By: jclaar
Date Posted: October 02, 2006 at 1:22 PM
Tachometer NOT RED / lt. green or red
From DEI's site.[
Posted By: shaggy12volt
Date Posted: October 02, 2006 at 4:09 PM
WIRING INFORMATION - FORD / F SERIES LIGHT DUTY / 2006 / Remote Start [PRINT THIS PAGE]
| 12volts | lt. GREEN/ purple (20A) | + | ignition harness | | Starter | RED / lt. blue | + | ignition harness | | Second Starter | N/A | | | | Ignition | dk. blue/lt. green | + | ignition harness | | Second Ignition | N/A | | | | Third Ignition | N/A | | | | Accessory | BLACK/ lt. green | + | ignition harness | | Second Accessory | N/A | | | | Keysense | BLACK/ pink | + | ignition harness | | Power Lock | pink / YELLOW | - | DKP or BCM, green plug, pin 9 | | Notes: The BCM (Body Control Module) is on the driver side rear cabin wall. | | Power Unlock | pink/lt. green | - | DKP or BCM, green plug, pin 1 | | Notes: The BCM (Body Control Module) is on the driver side rear cabin wall. | | Lock Motor | pink/black | 5wi | DKP or BCM, blue plug, pin 2 | | Notes: The BCM (Body Control Module) is on the driver side rear cabin wall. | | Unlock Motor | RED / orange | 5wi | DKP or BCM, blue plug, pin 5 | | Notes: The BCM (Body Control Module) is on the driver side rear cabin wall. | | Parking Lights+ | brown | + | switch or BCM, blue plug, pin 6 | | Notes: The BCM (Body Control Module) is on the driver side rear cabin wall. | | Parking Lights- | N/A | | | | Hazards | same as turn signal wires | | | | Turn Signal(L) | lt grn/wht (F), lt grn/org (R) | + | turn signal switch | | Turn Signal(R) | wht/lt blu (F), org/lt blu (R) | + | turn signal switch | | Reverse Light | BLACK/ pink | + | DKP, gray plug, pin 13 | | Door Trigger | BLACK/ yel (L), BLACK/ pink (R) | - | DKP, gray plug, pins 22, 23 | Notes: The wiring above is for vehicles without keyless entry. Vehicles with keyless entry, the door trigger wires are found at the BCM, green plug. The LF door trigger is BLACK / YELLOW in pin 4. The RF door trigger is BLACK/ pink in pin 5. The LR door trigger is BLACK/ lt. blue in pin 12. The RR door trigger is BLACK/ white in pin 13. Use all wires and diode isolate each.
The BCM (Body Control Module) is on the driver side rear cabin wall. | | Dome Supervision | BLACK/ lt. blue | + | DKP, gray plug, pin 6 | | Trunk/Hatch Pin | N/A | | | | Hood Pin | N/A | | | | Trunk/Hatch Release | N/A | | | | Power Sliding Door | N/A | | | | Factory Alarm Arm | N/A | | | | Factory Alarm Disarm | N/A | | | | Disarm No Unlock | N/A | | | | Tachometer | NOT RED / lt. green or red | ac | any ignition coil or fuel injector | | Wait to start | N/A | | | | Brake Wire | lt. green | + | brake pedal switch | | Parking Brake | lt. GREEN/ red | - | parking brake switch | | Horn Trigger | dk. blue | - | switch or BCM, blue plug, pin 12 | | Notes: The BCM (Body Control Module) is on the driver side rear cabin wall. | | Memory Seat 1 | BROWN / lt. green | - | memory seat switch on seat | | Memory Seat 2 | BLACK/ orange | - | memory seat switch on seat | | Memory Seat 3 | N/A | - | |
| Interface Module: | Category: Immobilizer Bypass | Required: Yes | Type: SecuriLock | | Part #: 1100F | | Alternate Part1 #: 556SW | | Alternate Part2 #: 556UW | | Alternate Part3 #: DesignTech 20402 | | Alternate Part4 #: DesignTech 29402 | | Notes: Standard on all models. |
| Smart Starter Kill Relays: | Relay Type: Starter Relay | Location: Underdash, Passenger side fusebox, #1 | | Part #: 6401A |
------------- The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
Posted By: dasbogie
Date Posted: October 02, 2006 at 6:03 PM
Thanks for the help everyone. I got all the other connections I need buttoned up. I just for some reason can't get the tach signal . On each fuel injector there is only two wires. All of them have a red one and a tan/black or something else. I have just tried the tan because I read the wire map online. If I test the tan wire(with a dmm) with the truck running what should it read 14v dc cause that's what i get.
Posted By: kh24
Date Posted: October 03, 2006 at 9:39 AM
The tach wire should be ac current and the volts should relate to what the tach is telling you. For example if you are at 1000 rpms you should have 1 volt ac and if you were at 2000 rpms you should have about 2 volts ac and so on.
Posted By: vpsr6
Date Posted: October 03, 2006 at 12:57 PM
I have a question as it pertains to the above diagram, I have an 05 F-150 supercab XLT. In connecting the power door locks it refers to the green connector in the driver side well by the e brake. The pins for the lock and unlock in the diagram say pin 1 pink/lt green unlock and pin 9 pink / YELLOW lock. I have found those wires on pins 8 pink/lt green (and there is another on pin 15) and pin 6 pink/ yellow . Is there an error somewhere or are they refering to pins on another connector. I am just finishing up the connections and have not plugged in the Python to it yet to see if it works. Just curious???
Date Posted: October 03, 2006 at 1:04 PM
test them with a meter should read 12v then go to 0.00 whe you hit the switch or go to the rear cabin and get them there you sould always test your conections anyways just dont go hooking up wires
Posted By: dasbogie
Date Posted: October 03, 2006 at 8:03 PM
Thanks to everyone who responded, I appreciate it very much. Turns out I did have the right tach wire, my valet switch was not functioning. I plugged a new valet switch in, started the truck and God Bless America, it learned the tach signal. With th key in I can remote start it. Thanks again for the help
