dei 555f pats interface?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83719
Printed Date: March 27, 2026 at 6:05 AM
Topic: dei 555f pats interface?
Posted By: pepe1fetha
Subject: dei 555f pats interface?
Date Posted: October 04, 2006 at 11:16 PM
will the 555F interface work on a 2002 Explorer Sport Trac? if not, what is my options? ------------- pepe1fetha
Posted By: captainzab
Date Posted: October 04, 2006 at 11:27 PM
requires the 556s by dei
or
just buy a uncut key that works with the ford, program it, then put it in a 555u box.
both is the same
------------- Note: You Always Dont Get What You Pay For.
Date Posted: October 05, 2006 at 1:26 AM
so the 555F won't work? ------------- pepe1fetha
Posted By: kgerry
Date Posted: October 05, 2006 at 1:35 PM
555F = PATS 556S = SECURLOCK 1100F = BOTH ------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: Chris Luongo
Date Posted: October 06, 2006 at 7:30 AM
Right, the 555F is for older Fords. Plus, the idea of gluing the little pellet in place is dumb, and it takes too long to find a good spot.
Just get a Ford key that looks similar to yours (the long style), and put that in a bypass box; much easier and more reliable.
Take note that even a used Ford key from another car will also work. You might find a junkyard that has one laying around they'd sell you, or maybe the dealer or locksmith has a mis-cut key they'd sell you for a discount.
Date Posted: October 08, 2006 at 9:37 AM
You can use preprogammed keys from another ford, and use it to bypass transponder?
What about hondas and toyotas?
Posted By: shaip99
Date Posted: October 09, 2006 at 5:30 AM
i would be weary about using the 556u with the key i have had problems with that unit and the sport trac the vehicle for some reason does not start properly in cold weather when it is warm no problem but first thing in the morning they just dont like to work i went through 3 units and two installs before i gave up and bought a bypass from another shop and used that and first try no problems i contacted dei and they said it was a combination of the 556u and the cold and fords they just dont like to work together
------------- "Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd
all run around in a darkened room munching pills and listening to repetitive
music."-Kristian Wilson, Nintendo Inc.
Posted By: snotdobbs
Date Posted: October 10, 2006 at 8:05 PM
alot of fords have problems in the cold weather unless you secure the transponder ring properly......... get yourself an xk04 from xpresskits or bypasskits or audiovox they are pretty unbeatable no key required
