chdl7 and xk532 from bypasskit problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83815
Printed Date: March 28, 2026 at 4:10 PM
Topic: chdl7 and xk532 from bypasskit problems
Posted By: vitrox
Subject: chdl7 and xk532 from bypasskit problems
Date Posted: October 06, 2006 at 8:30 PM
I know i'm not the only one using these bypasses on the new dodges, jeeps, and chryslers. Has anyone gotten the 2nd start activation to actually work yet? I was doing a bit of testing today on a 06 ram and I tried to get it to remote start without doing the dual relay setup. I used only the module which is supposed to do the 2nd start and accessory activation. Well to sum it up, it didn't work. The truck actually started, so I know the 2nd start activation worked but i'm pretty positive that the 2nd accessory did not work. The (brake) and (abs) lights both came on almost immediately after start and within 5-10 seconds the (airbag) light came on. anyone got some insight on getting these things to work properly and eliminate the 2 relays? oh, and i eventually just cut the module wire and wired up the dual relays and it worked perfectly..
Posted By: Velocity Motors
Date Posted: October 06, 2006 at 9:45 PM
Have you tried the Knowledge Base from Trilogix to see if their techies have any insight on why it's not working ?
------------- Jeff
Posted By: vitrox
Date Posted: October 07, 2006 at 1:09 AM
i checked the knowledge base on bypasskits website but to no avail. I have however sent a message discussing this with their techs. I still have not heard back from them, but its only been 12 hours now.
Posted By: snotdobbs
Date Posted: October 09, 2006 at 6:56 AM
installed one on saturday..........flippin fantastic piece.....however after the install was complete i attempted to program the transponder and i got nothin so all the time i saved with the part was wasted on troubleshooting and tech support line hold time.....when i talked to the tech guys they basically read the manual to me....it was rather condescending.....anyways after all was said and donethe first part would not activate the mux circuit so it wouldnt program or do anything...luckilly i ordered many of these 532's and plugged a second one in....within seconds i was remote starting the truck and activating all the data options.....these new xpresskit parts are sweet used an xk04 and and xk05 on friday and they worked superbly......
Posted By: vitrox
Date Posted: October 10, 2006 at 11:50 PM
sometimes the vehicles will goto sleep, just wake em back up by using the factory keyfob.. we've had issues with all the new jeeps, chrysler and dodge. One didn't start after we were done putting an autostart in. All we did to fix it.. lock and unlock with factory keyfob, boom, fixed.
anyway, still no word back from tech support. Good thing i'm not holding my breath.
Date Posted: October 11, 2006 at 9:06 AM
Have you tried another module yet ?
------------- Jeff
Posted By: vitrox
Date Posted: December 29, 2006 at 7:29 PM
still haven't gotten these things to work, just tried again on an 07 dakota.. no 2nd start or accessory.
