audiovox aps786 remote start problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83859
Printed Date: March 29, 2026 at 9:29 AM
Topic: audiovox aps786 remote start problems
Posted By: derrickg
Subject: audiovox aps786 remote start problems
Date Posted: October 08, 2006 at 9:30 AM
i installed this system in a 94 olds bravada everything works except the remote start doesnt work when i try to activate it. the led flashes 5 times and the park lights flash 5 times and thats it there was some diodes in the box. i read something in the instructions about using one when used with alarm do i really need it. and also when u try to remote start it the dash doesnt light up just the led flashes.
Posted By: sparkie
Date Posted: October 08, 2006 at 11:38 AM
If the system is new, you may have to program the remotes for it to work. Audiovox units also usually require you to press the Channel #2 button twice to activate the remote starter. There is also usually two switches for the unit. One is a programming switch and the other a valet switch. Make sure the valet switch is OFF. It shuts down the remote starter portion of the unit, but the keyless functions will still work.
------------- sparky
Posted By: Mike M2
Date Posted: October 08, 2006 at 1:18 PM
I believe 5 flashes means the tach isn't learned. Either you didn't program it correctly or you haven't hooked up the right wire. The tach is a white wire on top of the coil...
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: derrickg
Date Posted: October 08, 2006 at 3:12 PM
i didnt know that you have to get the unit to learn the tach signal how do i do that
Posted By: audiopete
Date Posted: October 08, 2006 at 4:07 PM
you can do voltage sense just change setting 7 to voltage and give that a try
Posted By: Qinstaller
Date Posted: October 08, 2006 at 4:16 PM
RTFM!!!! if I remember correctly it's Ign. ON, press valet 3 times, turn key off, press and hold valet and start car with key, park lights will flash when tach is learned, release valet if lights stay on for 3 sec. tach is stored. Again RTFM!!!
------------- MECP Cert.
18 years Exp.
Support your local Installer
Still love what I do! :)
Date Posted: October 08, 2006 at 4:21 PM
sorry Pete no voltage sence on this model
18 years Exp.
Date Posted: October 08, 2006 at 4:24 PM
i do 786 all day at work setting 7 change to non tach if you need any help get back to me
Date Posted: October 08, 2006 at 4:43 PM
Well I dont do them everyday but a couple a month wouldnt be an exageration. and Im looking ant the manual as I type this and I show option 7 is Diagnostics as option 7 and Input Check as option 4 with tach as the only option. So not to disagree with your extensive daily knowledge but the facts dont agree. hear is a link to the PDF version javascript:OpenWin('/manuals/installation/APS786_DOC_IM.pdf')
18 years Exp.
Date Posted: October 08, 2006 at 4:47 PM
darn Link didnt work but can be found here APS786------------- MECP Cert.
18 years Exp.
Date Posted: October 08, 2006 at 7:33 PM
sorry about that was thinking of diff unit use # input check program na have manual in front of me
Date Posted: October 08, 2006 at 7:38 PM
#4 program key on program switch 3 times key off then trunk button on remote for 1 second then key on program switch 2 times then lock button 4 times then trunk button 1 key off
Posted By: Mike M2
Date Posted: October 08, 2006 at 8:52 PM
Setting tach is key on, valet 3 times, key off, press and hold valet, start car, lights will flash, release valet, lights stay on for 5 seconds, key off. Setting to voltage will work, program step 4 even tho they don't list it toggle it to two chirps anyway. Do the correct install and use tach setting, it's safer and the right way to do it... ------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: derrickg
Date Posted: October 09, 2006 at 7:58 AM
i just wanted to thank everyone who posted i programed it like you guys said and it worked perfectly thank you
