2006 chevy trailbazer ss remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83900
Printed Date: March 30, 2026 at 6:14 AM
Topic: 2006 chevy trailbazer ss remote start
Posted By: shaip99
Subject: 2006 chevy trailbazer ss remote start
Date Posted: October 09, 2006 at 5:18 AM
i am having trouble with a 2006 trailblazer ss.  i am  working with a command start cs580i and a dei 457g bypass(yes i know there are other units that are better but it is all i have access to). I am unable to get the door pins to work with this unit. To find the doomlight supervision wire directechs says to go to the fusebox under the rear seat(grey black wire). I am unable to find the wire there that tests correctly has anyone worked on these vehicles and if so have you been able to find this wire elsewhere or a common doorpin wire as in these vehicles you need to tap into multiple wires throughtout the vehicle and diode isolate them(which i am reluctant to do if i dont have to)
any help would be great
"Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd
all run around in a darkened room munching pills and listening to repetitive
music."-Kristian Wilson, Nintendo Inc.
Posted By: tee-tap1
Date Posted: October 09, 2006 at 11:03 AM
can also use wire at domelight it will cover all doors  check which door trigger you are using i believe it is positive but just test to be sure been a while .
Posted By: NowYaKnow
Date Posted: October 09, 2006 at 3:50 PM
Just run the wire up to one of the domelights it's easier. The domelight wire comes out the bottom of the rear fusebox you won't be able to access it there without a hassle.
Mike
Posted By: Mike M2
Date Posted: October 09, 2006 at 4:08 PM
I agree, i go to the dome light over the drivers door and get the gray/black positive. It's just easier...
Mike M2
Tech Manager
CS Dealer Services
