clifford 10.5 door lock?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83919
Printed Date: March 30, 2026 at 12:35 PM
Topic: clifford 10.5 door lock?
Posted By: truevietluv636
Subject: clifford 10.5 door lock?
Date Posted: October 09, 2006 at 4:33 PM
i just almost finished installing the clifford 10.5 alarm into my civic, the only thing i have left is the door locks. my old clifford alarm only had a two wire harness for door locks which was very easy to install, but the clifford 10.5 has a 7-pin harness and now i need some help. im using aftermarket actuators with two wires comming from each. could someone give me some information on how to install door locks. thanks.
Posted By: Mike M2
Date Posted: October 09, 2006 at 5:02 PM
Easy, purple and PURPLE / black to 12volts, BROWN / black and WHITE/ black to ground, and blue/black and GREEN/ black to your two actuator wires. Hook them up and if the locks are backwards reverse the green and blue. The BLACK/ white is your interior light polarity. That goes to ground on a Civic. Be sure to hook up the other BLACK/ white H14 to the door trigger and this will give you dome light supervision....
------------- Mike M2
Tech Manager
CS Dealer Services
Date Posted: October 09, 2006 at 5:28 PM
thanks alot!
