I can’t start my car due to alarm system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83975
Printed Date: April 01, 2026 at 5:56 AM
Topic: I can’t start my car due to alarm system
Posted By: snoopy123
Subject: I can’t start my car due to alarm system
Date Posted: October 10, 2006 at 9:29 PM
I have a rattler 310D alarm installed on Hyundai elentra.  The windshield was broken by someone last saturday nite, and I was out.  I found out when I was back on monday.  I can unlock/lock my car door with remote.  But, when I tried to start my car, the alarm light blinking and then siren, so I stopped it with remote.  When I tried to start again, same thing happened, I stopped it with valet button.  Now, the alarm light and siren will not blink or sound when I try to start, but the car still won't start.  It seem like i can't crank to start the engine......what should I do now?
Posted By: captainzab
Date Posted: October 10, 2006 at 9:59 PM
Disarming the alarm should have allowed for you to start the car (disable starter relay)
But since it didnt,Remove the ground from the rattler 310D so that the starter relay is disabled.
Starter Kill relay should be the only thing disabling the car.
Check your car battery.
Sucks to hear you got your car broken into, hope they didnt jack anything.
Note: You Always Dont Get What You Pay For.
Posted By: auex
Date Posted: October 10, 2006 at 10:27 PM
Did they get into the car or only break the window?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: October 10, 2006 at 10:44 PM
After I remove the ground from alarm system, should I reconnect it after I try to start engine?  or you want me to disconnect, and then connect before I try to start engine?  Thank you very much.
Date Posted: October 10, 2006 at 10:46 PM
The only broke the window.
Date Posted: October 10, 2006 at 11:07 PM
remove the ground and see if you can start your engine.
If this fixes the problem, then the alarm is giving the 'ground when armed wire' ground all the time.
usually the brain resets when you turn ignition on then off.
Date Posted: October 10, 2006 at 11:33 PM
I will try it tomorrow.  What do you mean "the alarm is giving the 'ground when armed wire' ground all the time" ?  Should I reconnect it?  When should I do brain resets?
Date Posted: October 11, 2006 at 12:34 PM
Problem solved.  Thanks.
