Security light, 2001 Olds Alero
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84599
Printed Date: May 07, 2026 at 1:56 AM
Topic: Security light, 2001 Olds Alero
Posted By: paddyboy
Subject: Security light, 2001 Olds Alero
Date Posted: October 25, 2006 at 7:31 AM
I have a 2001 Olds Alero.  I recently lost my key and had to drill out the ignition lock.  I was successful at my attempt and was able to remove the ignition lock.  I purchased  a new one at Chevrolet.  I brought them my title and reg and they retrieved the vehicle key code and cut me 2 new keys.  I took the keys and lock to a reputable locksmith due to time restraint as suggested by parts person.  The lock was coded to the keys and I then installed the new lock and reassembled everything.  The car starts and runs fine but I have a steady security light.  Is there an easy solution and if not, I'll take any information available.
Take nothing but photographs, leave nothing but footprints
Posted By: sparkie
Date Posted: October 25, 2006 at 3:11 PM
Your car has Passlock II. It is an immobilizer system built into the key/ignition cylinder/switch. It is separate from your key cylinder, but is a a part of the ignition barrel. It has three wires attached to it. Usually black, white and yellow. You may have damaged it in the process. I would suggest that you find a dealer or knowledgable mechanic that can repair it for you. There are many possibilities of what could have happened.
sparky
Posted By: paddyboy
Date Posted: October 25, 2006 at 4:23 PM
Ok, thanks much!
