1990 lincoln continental, seats, windows,
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84797
Printed Date: April 19, 2026 at 7:02 AM
Topic: 1990 lincoln continental, seats, windows,
Posted By: phattbazturd
Subject: 1990 lincoln continental, seats, windows,
Date Posted: October 29, 2006 at 7:52 AM
I have a 1990 lincoln continental  sig series .... here is my problem .... I am having an electrical problem   the power seats,windows and locks dont work... but everything else does  ( works fine ) I was wondering If anybody has encountered this problem or if anyone has a solution or know what is it I can check .......???
BigC
Posted By: fox55
Date Posted: October 29, 2006 at 5:24 PM
Check your owner's manual for all fuse locations. Check all fuses with a DMM. Alot of times one fuse will control multiple functions and sometimes just replacing one will solve many problems. Good luck.posted_image
MECP Certified
Fry's Electronics MEI - Anaheim, Ca
"Kneel Before Zod"
Date Posted: October 31, 2006 at 8:46 PM
was just wondering if anybody has a wiring schematic for 1990 linc cont power seats,windows,locks..... or if anytbody has any ideas on what to check for if all theses options are not working . I was told they all run off the same power source but i cant find it .... I have checked the fuses and they are fine but I still have no power running to the power seats,windows,and locks can anybody help please ....
BigC
Posted By: master5
Date Posted: November 01, 2006 at 1:15 AM
In a car that old all those circuits use breakers, not fuses. I do not have a diagram for that vehicle but older cars like that are typically very simple. A DMM is all you need to troubleshoot anything.
Now I don't know how many breakers there are or where they are but since all of those circuits are out you want to look for a "fusable" link. If you look by the solinoid which you can easily find on the fender, the main batt+ goes to one side, the other to the starter, and one or 2 thinner wires from the key switch. Coming off tthe battery wire you will see these other smaller wires with small rubber looking things on them. Take a meter and check that 12v+ is on the wire after the link. If not, go to an autoparts store and splice/solder on a new one.
Now if the link blows again one of those systems is dead shorted. You will need check each one individually and leave that shorted one disconnected for the other things to work. repair/replace the shorted component and all should be well.
Should do the trick, keep me posted.
