2000 WJ minimum remote start info
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84814
Printed Date: May 04, 2026 at 1:54 PM
Topic: 2000 WJ minimum remote start info
Posted By: dturano547
Subject: 2000 WJ minimum remote start info
Date Posted: October 29, 2006 at 2:50 PM
Im looking to run my remote start with the most basic install. I have done stereo, fog lights and a few oterh electrical installs but this seems a little intimidating getting under the dash.
i plan to solder everything in, thats the correct way, right?
Here is the diagram that came with my remote start. Can I just connect the critical wires to get this thing in quicjly or does everything have its own porpuse?
i.e. im not going to mind if it only unlocks the front driver door. Can i avoid connecting the heater lines if I plan to jst leave the heat on when I get out of the car?
Dont have much experince so IM not sure what you can skimp on in this type of setup. thank you.
also this is what came in the kit:
1-main control module, 1- three button remote transmitter, 1- 6 pin ignition harness, 1-5 pin harness, 1-8 pin harness, 1-2 pin valet switch, 1-3 [in antenna harness, 1 3-pin door lock harness, 1 hood switch, 1 hood and window decal.
THis is my first post and hope I didnt do anything incorrectly. Im a complete newbie to remote starters. I m currently browising throught the info on this site, thank you.
Date Posted: October 29, 2006 at 2:54 PM
Date Posted: October 29, 2006 at 3:06 PM
Im trying to do the install on a 2000 Jeep grand cherokee laredo 4.o V6
This is the system im putting in.
https://shelbyautosecurity.com/manual...l%20072104.pdf
I though it was Alert but when I opned the box it turned out to be carol shelby.
Posted By: Mike M2
Date Posted: October 30, 2006 at 6:42 AM
| 12volts | red and pink/black | + | ignition harness | | Starter | yellow | + | ignition harness | | Second Starter | | | | | Ignition | dk. blue | + | ignition harness | | Second Ignition | | | | | Third Ignition | | | | | Accessory | RED / black | + | ignition harness | | Second Accessory | BLACK/ orange | + | ignition harness | | Keysense | | | | | Power Lock | use Directed module 455JW | | | | Notes: If an interface module is not available, use ORANGE / black and pink/black at the driver door lock switch in the door to lock and unlock the driver door. Use ORANGE / purple and pink/purple at the passenger door lock switch in the door to lock and unlock all of the other doors. These wires are reverse polarity (5wi). | | Power Unlock | see power lock | | | | Lock Motor | ORANGE / black | 5wi | driver door lock switch | | Unlock Motor | pink/black | 5wi | driver door lock switch | | Parking Lights+ | use negative wire | | | | Parking Lights- | yellow | - | headlight switch | | Notes: The parking lights are negative trigger thru a 1300 ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. | | Hazards | dk. blue/pink | - | hazard switch | | Notes: The dk. blue/pink will flash the hazard lights. They will flash even with a latch input to the wire. | | Turn Signal(L) | | | | | Turn Signal(R) | | | | | Reverse Light | | | | | Door Trigger | see notes | - | see notes | | Notes: There are 4 separate door triggers wire, one for each door. Use all 4 wires and diode isolate each together. The drivers door is tan/red at the drivers door lock switch. The passenger door is tan/red at the passengers door lock switch. The drivers rear door is tan/orange and the passengers rear door is tan / YELLOW at the BCM. WHEN USING A 455J INTERFACE MODULE, IT IS NOT NECESSARY TO USE THE SEPARATE TRIGGER WIRES. USE THE YELLOW WIRE AT THE UNDERDASH LIGHT FOR DOOR TRIGGER. | | Dome Supervision | yellow/dk. green | - | BCM, above diagnostic plug | | Trunk/Hatch Pin | tan/black | - | BCM, above diagnostic plug | | Hood Pin | | | | | Trunk/Hatch Release | | | | | Power Sliding Door | | | | | Factory Alarm Arm | use Directed module 455JW | | | | Factory Alarm Disarm | use Directed module 455JW | | | | Notes: If an interface module is not available, use lt. GREEN/ orange at the driver door lock switch in the door. It is negative trigger thru a 463 ohm resistor. MUST use a relay. | | Disarm No Unlock | | | | | Tachometer | see notes | ac | see notes | | Notes: The 4.7L motor has a separate coil for each cylinder. Go to any coil and use any wire that is NOT dk. GREEN/ orange. On the 4.0L motor use any of the tan/stripe wires at the coil pack, or go to one of the fuel injector and use the wire that is NOT dk. GREEN/ orange. | | Wait to start | | | | | Brake Wire | WHITE/ tan | + | brake pedal switch | | Parking Brake | | | | | Horn Trigger | gray/orange | - | horn switch | | Memory Seat 1 | | | | | Memory Seat 2 | | | | | Memory Seat 3 | | | |
| Interface Module: | Category: Immobilizer Bypass | Required: Yes | Type: Sentry Key | | Part #: 555CW | | Alternate Part1 #: 556UW |
First you will need a bypass for the immobilizer if you have a gray keyhead. If the key is black, your ok, not needed. Second, locks are a pain because you have to run wires into both front doors. You can spend a little cash and buy an interface like the DEI 455J and save yourself some time and trouble. This will not only lock the doors for you but also interface the factory alarm if you have one... ------------- Mike M2
Tech Manager
CS Dealer Services
Date Posted: October 30, 2006 at 9:23 AM
Awsome, this is exptremely helpful. Would I be able to not hook up the lock/unlock feature until I buy the DEI 455J interface? I figure I can can wire the whole thing up then do the locks when the part comes.
Posted By: Mike M2
Date Posted: October 30, 2006 at 4:51 PM
You can do it that way. The 455J will need power and ground, plus a wire from the OBD2 connector under the dash...
Tech Manager
CS Dealer Services
Date Posted: November 01, 2006 at 5:47 PM
i actually got rid of the shelvy sytem and hooked up a Valet 561T Remote start, which i added on to my existing stock setup. I actually like it becasue i can use my stock keyless entry. My question is how can I extend the reach on my stock keyless remote. I just cut into the wire and am not wure where the transmitter would be for this.
