2002 mitsubishi lancer, alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84818
Printed Date: May 04, 2026 at 9:06 AM
Topic: 2002 mitsubishi lancer, alarm
Posted By: sheldondron
Subject: 2002 mitsubishi lancer, alarm
Date Posted: October 29, 2006 at 4:28 PM
yeah i bought a clifford martix rs3.5 and i need a wiring diagran for it i have a mit. lancer 4 dr. 2002. thanks
Posted By: KarTuneMan
Date Posted: October 29, 2006 at 5:33 PM
| MODEL | YEAR(S) | | LANCER | 2002 - |
| KEY | T-HARNESS | IMMOBILIZER | | N/A | N/A | N/A |
| PART | COLOR | LOCATION | | 12 VOLT CONSTANT | WHITE (+) | IGNITION SWITCH HARNESS | | STARTER | BLACK / YELLOW (+) | IGNITION SWITCH HARNESS | | STARTER 2 | N/A | | | IGNITION 1 | BLACK/ WHITE (+) | IGNITION SWITCH HARNESS | | IGNITION 2 | N/A | | | IGNITION 3 | N/A | | | ACCESSORY /HEATER BLOWER 1 | BLUE/BLACK (+) | IGNITION SWITCH HARNESS | | ACCESSORY /HEATER BLOWER 2 | N/A | | | KEYSENSE | N/A | | | PARKING LIGHTS ( - ) | N/A | | | PARKING LIGHTS ( + ) | GREEN/ YELLOW (+) and GREEN / WHITE (+) Use BOTH, See NOTE *1 | IN WHITE PLUG, AT BOTTOM OF FUSEBOX | | POWER LOCK | PURPLE (TYPE B) | @ DRIVERS DOOR HARNESS | | POWER UNLOCK | LIGHT GREEN (TYPE B) | @ DRIVERS DOOR HARNESS | | DOOR TRIGGER | WHITE (-) | IN WHITE PLUG, AT THE BOTTOM OF FUSEBOX | | DOMELIGHT SUPERVISION | USE DOOR TRIGGER, Requires Part #775 Relay | | | TRUNK RELEASE | N/A | | | SLIDING POWER DOOR | N/A | | | HORN | YELLOW (-) | @ STEERING COLUMN HARNESS | | TACH | BLACK / YELLOW or BLACK/ GREEN | @ COIL PACK | | WAIT TO START LIGHT | N/A | | | BRAKE | GREEN (+) | @ SWITCH ABOVE BRAKE PEDAL | | FACTORY ALARM DISARM | GRAY (-) | @ DRIVERS DOOR HARNESS | | ANTI-THEFT | N/A | |
