schematic for 06 nissan marano
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84965
Printed Date: May 04, 2026 at 6:59 PM
Topic: schematic for 06 nissan marano
Posted By: keithfish
Subject: schematic for 06 nissan marano
Date Posted: November 01, 2006 at 3:25 PM
i need a accurate schematic for a 2006 nissan marano. does any one have something
------------- trout
Posted By: Mike M2
Date Posted: November 01, 2006 at 7:51 PM
| 12volts | green (40A) | + | ignition harness | | Starter | BLACK/ red | + | ignition harness | | Second Starter | BLACK / YELLOW | + | ignition harness | | Ignition | BLACK/ red | + | ignition harness | | Second Ignition | N/A | | | | Third Ignition | N/A | | | | Accessory | red | + | ignition harness | | Second Accessory | WHITE/ blue | + | ignition harness | | Keysense | BLACK/ red (required) | + | ignition harness or BCM, pin 37 | | Power Lock | blue | - | driver door module in door, pin 4 | | Power Unlock | red (double pulse) | - | driver door module in door, pin 6 | | Lock Motor | purple | 5wi | BCM above accelerator pedal, pin 50 | | Unlock Motor | GREEN / WHITE | 5wi | BCM above accelerator pedal, pin 44 | | Parking Lights+ | RED / blue | + | driver kick, harness to rear | | Parking Lights- | N/A | | | | Hazards | GREEN/ red | - | BCM above accelerator pedal, pin 29 | | Turn Signal(L) | GREEN/ black | + | BCM above accelerator pedal, pin 45 | | Turn Signal(R) | GREEN/ YELLOW | + | BCM above accelerator pedal, pin 46 | | Reverse Light | GREEN / WHITE | + | driver kick, harness to rear | | Door Trigger | see notes | - | BCM above accelerator pedal | | Notes: The LF door is lt. blue in pin 62, the RF door is RED / green or red in pin 12, the LR door is RED / white in pin 63, and the RR door is RED / white or RED / yellow in pin 13. Use all four wires and diode isolate each. | | Dome Supervision | red | - | BCM above accelerator pedal, pin 48 | | Trunk/Hatch Pin | PURPLE / white | - | BCM above accelerator pedal, pin 58 | | Hood Pin | N/A | | | | Trunk/Hatch Release | GREEN/ blue | - | release relay in driver kick | | Power Sliding Door | N/A | | | | Factory Alarm Arm | arms with lock | | | | Factory Alarm Disarm | disarms with unlock | | | | Disarm No Unlock | single pulse power unlock wire | | | | Tachometer | NOT red or black | ac | any ignition coil or fuel injector | | Wait to start | N/A | | | | Brake Wire | RED / green | + | brake pedal switch | | Parking Brake | green | - | parking brake switch | | Horn Trigger | GREEN/ orange | - | horn switch | | Memory Seat 1 | lt. GREEN/ black | - | memory module left of column, pin 9 | | Memory Seat 2 | pink/blue | - | memory module left of column, pin 25 | | Memory Seat 3 | N/A | - | |
| Interface Module: | Category: Immobilizer Bypass | Required: Yes | Type: Transponder | | Part #: 556UW |
------------- Mike M2
Tech Manager
CS Dealer Services
Date Posted: November 02, 2006 at 12:47 PM
thanks for the reply, but the door triggers aren't accurate. they are negative, they only read around 2.5 volts. i have found all know execpt the rear left threw trial & error
------------- trout
